HID + pothole = HID off. WTH?
Discussion in 'Lighting' started by MJonaGS32, Dec 17, 2010.
  1. Dec 17, 2010 at 10:20 PM
    MJonaGS32
    MJonaGS32 [OP] MJ on a GS
    MJ
    SF Bay Area (East)
    07 LT 4x4 DCSB 6spd Vagabond
    Drifter wedge camper, Dual battery, OBA, ARB locker, 4.56 gears
    Sometimes when I hit a bump or speedbump, my driver side HID bulb turns off. Usually I have to turn the lights off, then back on to have both turn on again. I find this very annoying, but even worse, sometimes I try to flick the lights off and on, and then BOTH of them don't turn on.
    Is this a sign of a bad bulb or balast? Bad connection? Ground?
    BTW these are HIDs from Slim's very first Group Buy on Toyota Nation, so 2.5 years ago.
    Any help is appreciated.
  2. Dec 17, 2010 at 10:32 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Are these HIDs getting all their power from the stock headlight wiring or directly from the battery?
  3. Dec 17, 2010 at 10:34 PM
    MJonaGS32
    MJ
    SF Bay Area (East)
    The power is from the battery. They are hooked up to the driver side headlight, but only to trigger on/off.
  4. Dec 19, 2010 at 9:40 PM
    MJonaGS32
    MJ
    SF Bay Area (East)
    BUMP.
    Now my lights don't work at all. But I bet if I go over a big speed bump, they turn back on.
    Anyone know anything about this? Or is it time to get a new pair?
  5. Dec 20, 2010 at 9:40 AM
    MJonaGS32
    MJ
    SF Bay Area (East)
  6. Dec 20, 2010 at 9:41 AM
    98tacoma27
    Ben
    Not Beech Creek
    Have you checked all the wiring connections?
  7. Dec 20, 2010 at 9:47 AM
    MJonaGS32
    MJ
    SF Bay Area (East)
    Yeah. Actually the other night I went to check the fuses, hoping it was just an easy fix. I checked all of the 4 headlight fuses (R,L, & high beams) . After taking them out and puting them back in, only to see that all of the fuses were still good, my lights starting working! WTH right?
    Then 2 days later, they stopped working again. I'm stumped
  8. Dec 20, 2010 at 9:47 AM
    Juggernaut
    Juggernaut Captain
    Sacramento
    25 TRD OffRoad DCSB
    That's my guess. Good luck!
  9. Dec 20, 2010 at 9:48 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    If you can't fix it with a hammer, you have an electrical problem...
    Check your connections, usually if things go out when you hit a bump it means something is loose. Hard to tell if it's your ground or the hot wire since you need both to run the lights. I'd start with any non-factory wiring as it'll probably be easier to trace. See if any connections have corroded, wires rubbing and chaffed off their shielding, make sure grounds are tight, connections are still in tact, etc. Start with the simple stuff and go from there.
  10. Dec 20, 2010 at 9:50 AM
    FamouzStarz
    FamouzStarz The illest taco
    21 TRD PRO
    ICON Build and then some
    im gonna say the bulb went out, had this happen on my lancer two weeks ago, id pop in some new bulbs and try that 1st depending where you purchased them you might have a warranty on both the ballast and the bulbs
  11. Dec 20, 2010 at 9:52 AM
    98tacoma27
    Ben
    Not Beech Creek
    ^^this = this VV
    bad connection or ground
  12. Dec 24, 2010 at 10:22 AM
    MJonaGS32
    MJ
    SF Bay Area (East)
    Thanks for all the tips. I'll be working on all of this soon and I'll update how things went.
  13. Dec 24, 2010 at 10:25 AM
    danstacoma
    danstacoma Well-Known Member
    Dan
    pa
    07 Tacoma
    3 inch lift, painted badges, k&n cold air, cherry bomb, tinted windows, yellow fogs, and more to come
    sometimes it could mean the ballast too might wanna check that out maybe switch them and see if it does it too the passenger side good luck
  14. Dec 24, 2010 at 10:26 AM
    rmb_crew
    rmb_crew My other ride has 18,400HP!!!!!!
    Jacksonville, FL 30.243103, -81.591007‎
    2010 F150 XLT SuperCrew 4X4
    Access larado tonneau, magnaflow exhaust
    Make sure your grounds are not on a painted surface. its got to be a loose ground. I grounded mine to the same ground the stock headlights are going into.
  15. Dec 24, 2010 at 10:26 AM
    mrp192
    mrp192 REALLY!!
    Brent
    Cheney WA
    2017 Tacoma Dbl cab long bed.
    Hood Strusts, remote Start, truck came with Leveling kit and wheels.
    sounds like you have a short.. try changing your ground.
  16. Dec 24, 2010 at 10:28 AM
    MJonaGS32
    MJ
    SF Bay Area (East)
    I think you guys are right about the ground.
    I know exactly where it's grounded to and it isn't a very secure spot. In fact, the HIDs in my Hellas are also not working, and guess what, also grounded to the same spot.
    Looks like an easy fix. It's just so damn hard to work on the truck during the holidays
  17. Dec 24, 2010 at 10:48 AM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    When I had HID's in my previous vehicle I grounded them at a bad spot and it caused all sorts of electrical abnormalities. Strangely, the HID's worked still, but the rest of my lights and stuff acted all goofy. This happened using a factory ground location.
    I'd try and find a separate ground location for the aftermarket lights if you haven't already.
  18. Jan 1, 2011 at 11:47 PM
    MJonaGS32
    MJ
    SF Bay Area (East)
    I just wanted to update the thread.
    It ended up being a loose ground. Easy fix. Thanks for all the help guys!
