hid problems
Discussion in 'Lighting' started by 04trd, Jan 7, 2013.
  1. Jan 7, 2013 at 4:38 PM
    04trd
    04trd [OP] Well-Known Member
    Cleveland Ohio
    2015 f150 lariat
    weather techs, 20precent tint, leveling kit, back flip bed cover, rhino liner
    hey guys i have a set of hids in my taco, had a local shop do them not sure what brand or anything. They dont have any name on the ballasts or anything. i asked for the best kit he has to offer and he hooked me up with this kit. So here is my question after having my lights on for about a half hour i go into a store to buy a coffee, come out to drive away and my driver side light doesnt work. I flick my lights on and off about 20 times and the driver side finally light up. It has been doing this for the past month or so. Did he sell me a shitty kit or does something have to be replaced? its a pain in the ass to worry if my hids are on or not.
  2. Jan 7, 2013 at 4:39 PM
    YotaOverAll
    YotaOverAll Backyard Performance
    Jessie
    Panama City, FL
    02 Prerunner SR5
    3" Toytec spacers, Bilstein 5100s in the back with add a leaf and overloads removed.
    A couple peopl I know with HIDs hav this problem. Don't know what it is, but you're not the only one.
  3. Jan 7, 2013 at 4:40 PM
    GotLift37
    GotLift37 Bangers Runner
    down south
    07 4Runner 4WD
    2.5" front lift (leeper coilover) 1" body 16" Dick Cepek DC1 Black/polished 295/75/16 General Grabber AT2 Tinted Taillights 5% tint OEM Acura TSX HID Retrofit White LED dash light conversion
    if I had to make a guess i would say the ballast is on its way out. thats how mine happened with my fog lights.. they were elcheapo ebay though
  4. Jan 7, 2013 at 4:41 PM
    GotLift37
    down south
    07 4Runner 4WD
    If you know how, try to swap out the ballasts left for right. and see if it does it on the other side.
  5. Jan 7, 2013 at 4:41 PM
    rickmeseke
    rickmeseke subaru of america
    Ricky
    Brunswick, GA
    a white truck
    cheapo kits will cause bulbs/ballasts to not last long at all.
    the only 'offroad' shop here in town sells them and their xentec kits ($30 hit or miss kits) but they mark them up to 85 with free install. i cant tell you how many people i know who buy them from their and they dont work
    not that im dogging cheap kits, but its a hit or miss
  6. Jan 7, 2013 at 4:42 PM
    1LEGGER
    1LEGGER 1LEGGED BADASS
    San Antonio
    Spacer lift, nitto terra grappler 285/75/18, xd rockstars with white stars and bolts, two jl amps, infinity components, kicker 10", undercover tonneau, satisfied grill (in process)
    sub'd for an answer
  7. Jan 7, 2013 at 4:43 PM
    04trd
    Cleveland Ohio
    2015 f150 lariat
    ok ill try to switch the ballasts. the passenger side lights up all the time while the driver side is out. do high end kits have this same problem?
  8. Jan 7, 2013 at 4:44 PM
    04trd
    Cleveland Ohio
    2015 f150 lariat
    the kit wasnt cheap it was 250 installed. so im kind of at a loss
  9. Jan 7, 2013 at 4:47 PM
    GotLift37
    down south
    07 4Runner 4WD
    I have OEM HID ballasts from an acura tsx. going on 3.5 years with the OEM's. went just over a year with the ebay hids
  10. Jan 7, 2013 at 4:53 PM
    04trd
    Cleveland Ohio
    2015 f150 lariat
    from what people are saying my ballast is going bad? witch is causing it not to light up when its warm
  11. Jan 7, 2013 at 6:49 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    That would be my guess......if the ballast gets swapped to the other side and the problem follows to that side, then the ballast is ur culprit.
    Check obvious things too like grounding points and connections.
  12. Jan 7, 2013 at 6:53 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Also....... things do get shipped DOA, and not all companies have the same QC standards.
    Oem ballasts are expensive but ur paying for quality.
    The morimoto line from the retrofit source is cheap but their QC is supposed to be pretty good, and their customer service is top notch..... iirc its matt and andrew and they have high standards......they also have some oem ballasts for a couple pennies more.
    Sometimes u do get what u pay for......sometimes u just pay an arm and a leg for install which ironically only takes minutes.
    Keep us posted
  13. Jan 7, 2013 at 6:57 PM
    KenLyns
    KenLyns 8-in. Third Member
    Belly of the Beast
    4x4 TRD Off Road Full-Auto
    All-Pro Bumper, CBI Sliders, Icon Coilovers, BudBuilt Skids, aFe Intake, Icon VS Rear Shocks, Timbren Bumpstops, All-Pro UCAs, JDM Steering Wheel, ViAir Compressor, Klearz LED 3rd Brake Light, Pop-N-Lock Tailgate Handle, Husky Front Flaps
  14. Jan 7, 2013 at 10:48 PM
    09DBLCAB09
    09DBLCAB09 Well-Known Member
    $250 installed!!?!?! Ouch
  15. Jan 11, 2013 at 10:21 AM
    IgnorantlyAlberta
    IgnorantlyAlberta VA6DCO
    David
    edmonton
    06 SR5 Trail Rated, 16 Tundra CM TRD
    TC Uni Uppers, TC race lowers, TC shock tower gusset/ secondary shock hoop, Modified Pelfrey rear shock relocate, ATO shackle flip,radflo hydro bumps front and rear, Radflo 2.0 CO/ 14" rear, Arb rear air locker, ARB front bump/m8000, Road armor rear bump/m8000, FJ TransCase/ Twin sticks....other shit.
    Check your fuses. Ive seen this before. They loosen up or heat up and slightly melt making a poor connection.
  16. Jan 11, 2013 at 2:20 PM
    04trd
    Cleveland Ohio
    2015 f150 lariat
    It's weird. When they are cold they light up every time. But once and a while once they are warmed up and I turn them off after a 20 minute drive the left side won't turn on. I changed ballasts and it still did the same thing
  17. Jan 12, 2013 at 7:43 PM
    IgnorantlyAlberta
    David
    edmonton
  18. Jan 12, 2013 at 10:34 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    96.5 FrankenTaco & 03 Stock dbl cab
    BFG KM2 33x12.5 tires, Wheelers Type B rims, Allpro 1.5'' Wheel spacers w/extended thread lug nuts 2 Alpine 10'' Type Xs 2 Kicker 6X9s 4 Sony 5 1/4s Pioneer 4100 HU Sway bar removed 4 Hella 500 HIDs Frankenstein Leaf packs 1'' lift shackles Eibach coils 5100s front 10'' 5150s rear BAMF BPV bracket Deckplate mod Elite Front bumper Magnaflow 14'' muffler Elite Off Road Rear bumper with Tire gate with jerry can and fold down table, BAMF sliders, Custom Homemade Bed, rack/roof rack, CVT Mt. Shasta Roof Top Tent, 20lb CO2 tank, BAMF diff skid custom front skid, GM CS144 140 amp alternator Blitzpro 21s HAWK side LEDs Blitzpro Custom made side mirror lights, LightForce 240 Blitz llights, Piaa 510 ION fogs, XRC8 Winch w/in cab controls,
    I bet I know.
    When you try turning them on do you hear a buzzing happening?? If so what's happening is that side is arcing out.
    Try it in the dark usually you can see it happening.
    This usually happen post ballast. Why? Hid ballasts are basically transformers. They convert the 12v input to a 80-90v ac I believe. This is a much high voltage and allows the electricity to jump the wires easy. This is why the wires post ballast are usually very thickly insulated.
    I had this happen to my HID fit Hellas after I extended the post ballast wires. Same thing would happen. 3 would turn on when cold no matter what. Let them warm up and only 1 or two would. Sadly I used inferior wire and they arced out and rarely would all turn on. I solved this by wrap g all the wires in e tape. Solved it instantly.
    So I'd try wrap each individual wire up in e tape..
  19. Jan 13, 2013 at 12:10 AM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Also, "flicking" them on and off 20 times will severely shorten the life of the lamps.
    When they kick on, the electrodes leave deposits on the glass. If they get up to temp, those deposits are pulled back into the electrodes.
    Short cycling is a VERY early death for HID lamps.
  20. Jan 13, 2013 at 12:12 AM
    Rich91710
    Rich
    Los Angeles
    08 Base
    It's actually closer to 2000vac, and at a very high frequency.
