HID Projector wiring help needed bad!
Discussion in 'Lighting' started by alove0750, Sep 4, 2011.
  1. Sep 4, 2011 at 2:54 PM
    alove0750
    alove0750 [OP] Well-Known Member
    Adam
    Concord, nc
    01 Tacoma Pre-runner
    Bilstein 5100's and OME 882's in the front AAL and Bilstein 5125's in the rear Converted to 4x4, with 97 front diff with manual hubs 4.56 Yukons front and rear Custom front bumper, sliders and under-belly skid by MOBS Fab in Concord,NC with built in hella's and 8000lb smitty
    I purchased the D2S kit from retrofit source and they came with zero instructions. I was able to get everything wired up and the retros in the lights, but I only have low beams... this is my first time messing with HID's or any kind of wiring for that case. What am I missing?
    I also purchased their plug n' play kit for my fog lights (Hella FF75) I wired them up and got nothing? I have a good connection to the battery and my grounds are solid, but I don't have any juice? Any kind of help or leads in the right direction would be great. Thanks for reading!
  2. Sep 12, 2011 at 8:20 PM
    alove0750
    Adam
    Concord, nc
    Just though I would update. I got everything in and the fogs wired up but I still have no high beams. Here are a few pics of before and after
  3. Sep 13, 2011 at 8:15 AM
    Yota Toy
    Yota Toy Taco Sauce
    FX retros, Blazer fog-light retro, JVC KW-NT30HD head unit, Pioneer 6X9's in front doors, Pioneer 6.5's in rear doors, two Pioneer 12" subs in sealed boxes, Sony X-Plod amp, Hidden Hitch trailer hitch, EGR window visors, two PIAA low-tone horns, Westin light bar with two 100-watt KC low profile driving lights.
    If those are bi-xenon projectors they have a solenoid that needs to be connected. One of the solenoid wires goes directly to ground, the other goes to the factory high beam wire (that gets +12V when activated). Polarity doesn't matter as far as the solenoid goes.
  4. Sep 13, 2011 at 8:57 AM
    saugus
    saugus Well-Known Member
    How did you fit the projectors? Did you have to cut those holes? How did they hold on to the housing?
  5. Sep 13, 2011 at 12:06 PM
    alove0750
    Adam
    Concord, nc
    What do you mean by the solenoid needs to be connected? The wiring harness had a high and low beam plug?
    The projector fits into the factory hole. It's held in by a lock nut. The only cutting I had to do was to the bottom of the shroud. It had a few minor clearance issues.
  6. Sep 13, 2011 at 12:30 PM
    Yota Toy
    Yota Toy Taco Sauce
    Are they bi-xenon projectors with a solenoid that moves the shield up and down? It sure looks like I see a solenoid wire in this picture:
  7. Sep 13, 2011 at 8:03 PM
    alove0750
    Adam
    Concord, nc
    Yeah, they have the solenoid. It had everything already wired up, all I had to do was push the spades into a connector and it plugged into the wiring harness
  8. Sep 13, 2012 at 7:48 AM
    Rebel Taco Man
    Rebel Taco Man Well-Known Member
    Tyler
    Kentucky
    2002 Manual TRD SR5 4x4
    Bilsteins front and rear, Eibachs up front, 2" Toytec AAL in rear, Diff Drop, Grey Wire Mod, Kobalt tool box, Bulldog Keyless entry, Sportsman max-4 seat covers, modded EL Bazooka basstube, Friends of Coal sticker and license plate, Green Hooks, Green Emblems, Green LED sony radio, Green shiftknob.
    ever get this problem fixed? would love to do projectors, and yours look the best from all ive seen...
  9. Sep 13, 2012 at 8:01 AM
    Sandman614
    Sandman614 Travis #hotsavannahdotcom, LRGRNR
    Tim
    Boone, NC\Garner, NC
    '06 SR5 Off Road
    Sounds like you didn't put the spades in the correct side of the connector for the high beams.
  10. Sep 13, 2012 at 8:43 AM
    ambiguous
    ambiguous Master Retrofitter @RECHELON/AESTHETICS Vendor
    Burt
    Portland, OR to SoCal
    2012 DCLB TRD
    Agreed. Also might want to check if you blew any fuses.
  11. Sep 13, 2012 at 9:12 AM
    alove0750
    Adam
    Concord, nc
    You can swap them back and forth, doesn't make a difference.
  12. Sep 13, 2012 at 9:42 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    Might be how the switch is wired. On my truck the low beams would be on fine. When I turn on my high beams the low beams go out. One set of bulbs is on at a time.
    If this was the case for you the low beams would turn off and the "high beams" would move the actuator in the projector. How did you lights work before the switch(factory setup)? Maybe a dual filament bulb, was there only one filament lit at a time?
    Just a thought
