HID quality lights
Discussion in 'Lighting' started by LBFD2005, Dec 23, 2012.
  1. Dec 23, 2012 at 9:56 AM
    LBFD2005
    LBFD2005 [OP] Its tha Southern Way
    MS
    11' Trd 4x4 6" pro comp
    procomp 6'' catback dual exhaust flowmaster 44 series
    Where is the best place for HID's? I bought some ebay ones and i know its a matter of time before they fail they just came included with some lights i got so i wanna make sure i have xtra's when they go out
  2. Dec 24, 2012 at 1:43 PM
    TRD Toy85
    TRD Toy85 Well-Known Member
    CT
    loaded 2013 TRD sport
    I purchased DDM and wasnt much more impressed then the ebay ones, 2 issues with ballasts within a year, yes the sent me replacements free of charge but it was still a hastle and a headache.
    Next time around Im going to spend the $ on a quality set.
  3. Dec 24, 2012 at 6:20 PM
    LBFD2005
    MS
    Where you buying from next?
  4. Dec 24, 2012 at 6:52 PM
    TRD Toy85
    CT
    Everyone seems happy with the products from theretrofitsource.com
    , everything seems like top quality .
  5. Dec 24, 2012 at 7:10 PM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
  6. Dec 24, 2012 at 7:41 PM
    GotLift37
    GotLift37 Bangers Runner
    North East AL
    07 4Runner 4WD
    2.5" front lift (leeper coilover) 1" body 16" Dick Cepek DC1 Black/polished 295/75/16 General Grabber AT2 Tinted Taillights 5% tint OEM Acura TSX HID Retrofit White LED dash light conversion WMW roof rack
    Phillips bulbs is what I use. all my hid parts are oem acura tsx. ballasts, bulbs and projectors
  7. Dec 24, 2012 at 8:35 PM
    fallon
    fallon Well-Known Member
    Colorado
    TRD Sport 4x4
    +1 for TRS. If you are going to put in HIDs dull a full retrofit and put in a projector don't just put in Plug 'n Play HIDs. The PnP kits glare horribly and blind people.
  8. Dec 25, 2012 at 3:59 AM
    TRSAndrew
    TRSAndrew Instagram: @apissues Vendor
    ATL
    ‘22 4Runner, ‘14 F150, and I’ve had 4 Tacomas (‘12, ‘15, ‘16, ‘18), 2 FJs
    TRS. Oh wait...
  9. Dec 25, 2012 at 5:12 AM
    TRD Toy85
    CT
    Speaking of retrofit , anyone do a set of 2012 or 2013 fogs yet ?
  10. Jan 2, 2013 at 11:32 AM
    LBFD2005
    MS
    so looked on TRS and they only come up to 6000k in a dual beam anyone now anywhere else to get the duals beam from??
  11. Jan 2, 2013 at 11:34 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    TW member SlimCubby! 2 years and just had a slight issue with a connector corroding, replaced the $2 connector and is all good.
  12. Jan 2, 2013 at 11:44 AM
    fallon
    Colorado
    TRD Sport 4x4
    There is a reason for that... Anything over 6,000k (actually even 5,000k) begins putting out significantly less visible light. The higher the number the more blue the light (or purple at really high kelvin), but the less people can see that light. Higher kelvin temps also create more glare than in the proper range, so not only are they providing less usable light, they actively make things harder for everybody on the road to see.
    Stay under 5,000k if if you actually want your lights to light up the road.
  13. Jan 2, 2013 at 11:45 AM
    AsianAnts
    AsianAnts just an AnT
    AnT
    Southern California (San Diego County)
    2011 PreRunner TRD Sport L/B Grey Metallic
    -Satoshi Grille Upper/Lower/Triangles -LED Map Lights, LED Dome Light, LED License Plate Lights -No front license -Wet Okole -Weather Techs (digi) -Running Boards -Bed Extender -AFE Cold Air Intake 2SI Dry Filter -Tailgate Hose-Clamp Mod, Tailgate washer Mod -Combi chain lock on bed extender -no chime w/ key in ignition & open door -Fog Light anytime -Slim Cubby's 3kHID fog -bumper plugs -keyhole plug -TRD license plate frame -combi-lock storage -rear TSB -window tint -camera mod -Painted radiator/engine covers -LS460 RetroFit -Bed Tie-Downs -LED Gauge Cluster, radio, clock and AC -Bed Mat -Extra DRings -Painted center console, radio unit, ac panel, overhead console.
    +1 TRS. outstanding customer service as well
  14. Jan 2, 2013 at 1:45 PM
    GotLift37
    North East AL
    07 4Runner 4WD
    x2.couldnt have said it better myself
  15. Jan 26, 2013 at 9:09 AM
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    TRS for the win! Anything over 6000k is gay.
  16. Jan 28, 2013 at 11:30 PM
    ornithology
    ornithology Active Member
    ...make sure it's in a projector and not in the stock housings :)
  17. Jan 29, 2013 at 8:24 AM
    fallon
    Colorado
    TRD Sport 4x4
    I second that. One of my ballasts stopped working after a month. I swapped ballasts & the problem followed the ballast. Called em up & they would have just had me do the troubleshooting I'd already done had I not already done it. Cut off the wires on the defective ballast & send a photo of the destroyed defective showing the destruction & serial number. The replacement ballast showed up a few days later.
    I must say that driving with 1 FX-R for a while was as good as or better than the light from 2 normal halogen bulbs.
