HID Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by banzaikid1, Jan 3, 2009.
  1. Jan 3, 2009 at 3:09 PM
    banzaikid1
    banzaikid1 [OP] Well-Known Member
    The other nite I installed my bixenon headlights and when I was trying them out the driver side didn't come on one time and I just turned them off then back on and it worked. Also the other day the passanger side did the samething. What do you guys think could be the problem?
    Thanks
    Brad
  2. Jan 3, 2009 at 3:19 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    sounds like you might have a bad connection somewhere.
  3. Jan 3, 2009 at 3:28 PM
    TacoCo
    TacoCo Aspiring wrench monkey
    Colorado
    09 TRD Off-Road DC V6 Magnetic Gray
    Snugtop XV Shell, Yakima Rack, AFE Pro Dry Filter, Secondary Air Filter Removed, Michelin AT2's, Partially Debadged, HID conversion, Dynomax Super Turbo Muffler, Rear leaf spring TSB, Foglights always on Mod, URD Short Throw Shifter, Toytec Coilovers on the way!
    Grounding, make sure you scrape off the paint where they're grounded so they're touching metal.
