HID recommendations
Discussion in 'Lighting' started by OSOQWK, Feb 23, 2011.
  1. Feb 23, 2011 at 5:35 PM
    OSOQWK
    OSOQWK [OP] Member
    Hawaii
    09 2.7 PreRunner
    K & N Air Charger Pioneer 920B Black Head lights Black Tail lights Color Matched Grille Hids
    My taco failed the safety inspection here b/c my HIDs dont have a hi beam setting...
    can anyone recommend a good HID bulb that has both hi and low settings.
    Thanks.
  2. Feb 24, 2011 at 12:16 AM
    rossk35
    rossk35 Do Work Son!
    hawaii
    07 TRD Sport Supercharged
    TRD S/C/TRD Intake/TRD Boost Gauge/DT Headers/OEM TL/ZKW retro/Pioneer DVD w/Ipod/Magnaflow/20% Tint/BHLM/JL 10" sub, JL VR components, JL 450/4 amp/Helwig Sway bar/Viper 791/ 18" limited 4runner rims
    just put the stock bulbs in to get safety check then put the hids back in after.
  3. Feb 24, 2011 at 12:17 AM
    BulletToothTony
    BulletToothTony Im only a dick 90% of the time
    You can call me Susan if it makes you happy.
    X2
  4. Feb 24, 2011 at 8:47 AM
    PreRunnerSeth
    PreRunnerSeth Well-Known Member
    Apex, NC
    15 Black DC OR Prerunner
    Ballast is the same... you need telescoping bulbs and the associated wiring harness that makes them work.
  5. Feb 24, 2011 at 7:27 PM
    OSOQWK
    OSOQWK [OP] Member
    Hawaii
    09 2.7 PreRunner
    M..F.. my stock bulbs got trashed in a front end collision this past june.... i guess i could check auto zone for some cheap replacements.... i didnt think hi/lo hids were so complicated.
  6. Feb 25, 2011 at 3:39 PM
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    4.88s w/h rear Powertrax locker, Fox 2.5 Ext. RR COs, Camburg 1.25” ucas, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, 315/75/16 BFG KM2, 16x10" custom beadlocks, BFF front hybrid, GSF rear HC, Relentless Fab ifs skid, BAMF lca skids, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, LCE Dual Comp clutch, URD ss, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, ARB compressor, Grillcraft, FXR TRS, T1 eyelids, 500 hellas w/h 6k hid conv., custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers, Weather Tech
    Phillips Bi-xenon!
  7. Feb 25, 2011 at 3:41 PM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    sig pic.........explain
  8. Feb 25, 2011 at 4:14 PM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    he was my only friend! poor little guy
