HID Relay Harness ?
Discussion in 'Lighting' started by dysfunctnlretard, Aug 14, 2009.
  1. Aug 14, 2009 at 6:26 PM
    dysfunctnlretard
    dysfunctnlretard [OP] Hi
    Manny
    CA
    2010 FJC
    55w HIDs, 16" Countersteer Offroads, Yokahama All Terrains, Demello Sliders
    Well I havent failed yet but feel like Im going to. I just bought a set of bixenon (55w) h4's and (35w) h10's for my taco, gotem from DDM Tuning. I was told to get the relay harness just to be safe and so I ordered 2, one for the fogs and the other for the hi/low beams. I just got the set today and my question is, what does the relay harness actually do and does the hi/low controller come with one already? What does the relay harness plug into?
    My understanding is that the relay harness allows for you to draw power directly from the battery, does this mean that both my fogs and hi/lows should be connected to the battery with the harnesS?
  2. Aug 15, 2009 at 1:57 AM
    sincitytaco
    sincitytaco Well-Known Member
    Las Vegas
    Icons, Bilstein 5100, Rear Leaf TSB, 17x9 American Racing Chamber Teflon, 275/70/17 Goodyear
    You dont need to worry about a harness for your fog lights. And you only need to use a harness if you are running bi xenons so yes you will need to use it for your headlights.
  3. Aug 15, 2009 at 2:45 AM
    rb11701
    rb11701 Oh yeah!
    Rob
    '09 Silver Streak TRD Off-Road
    Rear Suspension TSB, DTRL Mod, aFe Pro-Dry S,USA Spec PA15-TOY iPod Adapter, Dynolock Tailgate Lock, UltraGauge OBDII Scanner, CoverKing Neoprene Seat Covers
    I would put both on seeing you already have 2. The problem (well not really a problem) is the hids needs some juice to power up. Once they are lit, they are fine. The thinking is that the smaller OEM wiring is not really up to par for the addition juice needed. So there is a possibility of frying you wiring system. So you hook the harness onto the battery and then plug the harness into to the ballast. Kinda like running a power line off your battery to run your stereo amps.
    Good idea to use them. I think the hi/lo's from DDM come with a realy but I am not sure if it is the same one as they sell. Worst case if it is and you can't return it, keep it as a spare in case something happens to one.
  4. Aug 15, 2009 at 7:43 AM
    Viet2100
    Viet2100 Well-Known Member
    Viet
    Delray Beach, FL
    2007 Infiniti G35S
    It is recommended but not necessary. I have never used them but that may just be luck.
    The relay harness is to protect your factory harness. Hook up the connections per labeled.
  5. Aug 15, 2009 at 10:09 AM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    Has nothing to do with running bixenons vs in the foglights. That's not where the problem is. The problem is as mentioned above, when they first fire up they draw a lot of current, which theoretically could fry your stock wiring harness. So this could happen with them in your lows, in your fogs, wherever. No difference. With the relay harness, your HID's get power directly from your battery rather than through your factory harness.
    As mentioned, people run HID's without a relay harness and have had no problem. Me personally, I'd never do it, especially with how cheap the relay harnesses are. Cheap insurance IMO.
