HID Replacement Bulbs
Discussion in 'Lighting' started by mshane06, Oct 11, 2011.
  1. Oct 11, 2011 at 7:17 PM
    mshane06
    mshane06 [OP] Member
    Shane
    El Centro, CA
    96 Tacoma LX
    Back in June i purchased some HIDs for my truck and i got the 6,000K bulb. I don't mind the blue tint that the bulb has, but i want a little brighter bulb. I have been looking at the 5,000K bulb which is the brightest that i have found. My question is: If i want to switch the 6,000K bulb to the 5,000K bulb, do i need to buy an entirely new kit or can i just purchase the bulb by itself and replace it?
    Any help would be grateful
    :D
  2. Oct 11, 2011 at 10:16 PM
    RIDDICK3
    RIDDICK3 nuckin futs member
    Stefan
    Orem, Utah
    Icon, omd, lr uca, bed speakers, t-rex grill, 170 striker lights.
    You should just be able to buy new bulbs.
  3. Oct 12, 2011 at 3:14 AM
    Joe02TRD
    Joe02TRD Well-Known Member
    Joe
    Woodbridge, CT
    4cyl 5sp 4x4 SR5 TRD
    You can buy just the replacement bulbs, I would go with 5000K. I have had good luck with DDM products.
  4. Oct 12, 2011 at 9:18 AM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    Correct, and I have tried 4300, 5000, 6000 at 35 watts... this is in 8" Hella 4000 off road racing lamps.
    I find 5000K the whitest/ brightest color of those three. I did notice a bit of yellow in the 4300s, and the 6000s were way way too blue (some said they looked like 8000K).
    5000K was a perfect blend. However, mine are 'cheap' Chinese bulbs from GG Lighting and the light 'moves' or flickers after they warm up... As long as they don't fail, I can live with that.
  5. Oct 12, 2011 at 9:25 AM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
  6. Oct 12, 2011 at 9:44 AM
    stunt man hans
    stunt man hans DISPLACED VIKING LIVING IN GEORGIA
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    FULL AEV PROSPECTOR KIT++
    call trs they carry every configuration of hid bulbs and their morimoto bulbs are of much better quality than anything else save for oem and depending on which oem bulb you choose they can be 2 to 4 times as expensive! 5k for light and color should be your choice don't go above that color temp if you want the brightest light.
