HID Retrofit (FX-r Bixenon projectors) GB
Discussion in 'Group Buys' started by RacerAV, Apr 7, 2011.
Thread Status:
Not open for further replies.
  1. Apr 25, 2011 at 7:57 PM
    #661
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    yes signifigantly
  2. Apr 25, 2011 at 9:57 PM
    #662
    mcleod90
    mcleod90 150,000 miles and counting
    sean
    modesto ca
    05 double cab
    hmmmm very tempting. how long is this group buy for?
  3. Apr 26, 2011 at 2:20 AM
    #663
    RacerAV
    RacerAV [OP] Well-Known Member
    OC, CA
    '09 DCSB4x4 (sold)
    pretty sure its over now, but give it a shot! cant hurt
    Adamo
  4. Apr 26, 2011 at 2:56 PM
    #664
    shredtacoma
    shredtacoma Well-Known Member
    Jace
    SOCAL
    07 Prerunner Debadged with snugtop
    Camburg lift, ProComp rims, Nitto Terragrappler tires, snugtop, Flowmaster exhaust and Airraid intake
    Ive been sanding down the inside of my gatling 2.0 shrouds to try and make my morimoto minis fit inside but thet will not fit??? anyone have any ideas??
  5. Apr 26, 2011 at 5:47 PM
    #665
    Slimwood Shady
    Slimwood Shady I love your mom!
    Linwood
    San Antonio, TX
    '23 TRD Pro Tundra; 996TT; '16 Odyssey
    #nomods
    Is this any better?
  6. Apr 26, 2011 at 6:56 PM
    #666
    Kram925
    Kram925 Active Member
    2010 Tacoma TRD Sport
    I am in the process of installing my HID's can anybody post some pictures of how you ran the wire harness and where might be a good spot to mount the ballast?
  7. Apr 26, 2011 at 7:44 PM
    #667
    Pingo
    Pingo Well-Known Member
    North Pole, AK
    2014 S/C TRD Offroad A/C
    I don't believe I have the gatling 2.0's I thought I had the original gatlings but I can't get the shrouds to even reach the housing over the projectors. Anyone installed gatlings that had this issue?
  8. Apr 26, 2011 at 8:15 PM
    #668
    RacerAV
    OC, CA
    '09 DCSB4x4 (sold)
    id call the retrofit source before you do anything else... they should all fit right...
  9. Apr 26, 2011 at 8:16 PM
    #669
    Pingo
    North Pole, AK
    this is what I'm talking about, not sure if you can tell but there is about a half inch gap maybe more between the end of the shrouds and the headlight housings... Can't get it any further over the projectors...
  10. Apr 26, 2011 at 8:18 PM
    #670
    RacerAV
    OC, CA
    '09 DCSB4x4 (sold)
    definitely doesnt look right, the projector sits too far inside the shroud too, yeah id call them tomorrow for sure.
  11. Apr 26, 2011 at 8:20 PM
    #671
    TmecTaco79
    TmecTaco79 Well-Known Member
    Adam
    Escondido,CA
    06 TRD PreRunner 4x2
    Bilstein 5100's, 33" BFG AT, Magnaflow
    with the gatling shrouds do they just slide over the projector and attach to the reflector bowl cause mine fit like the ones above also.
  12. Apr 26, 2011 at 8:24 PM
    #672
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Are those just issues in the first gens?
  13. Apr 26, 2011 at 8:24 PM
    #673
    Pingo
    North Pole, AK
    Here's another picture I don't know if this helps at all... tmectaco is this the same problem you're having but in a 2nd gen housing?
    edit: It's hard to tell but there is a large gap between the shroud/housing. . . Trimming doesn't appear to be an option because of where the projector is hitting the shroud. Either I'm missing something and doing it completely wrong or I got the wrong projectors or need new shrouds or something.
  14. Apr 26, 2011 at 8:26 PM
    #674
    TmecTaco79
    Adam
    Escondido,CA
    ya but i dont have my housings apart. but i was test fitting the shrouds to the projectors and they seem to be sitting a little deep in the shroud.
  15. Apr 26, 2011 at 8:28 PM
    #675
    memario1214
    Colton
    Missoula, MT
    Those appear to be the original Gatlings... But I haven't taken mine apart yet so stuff like this makes me nervous.
  16. Apr 26, 2011 at 8:29 PM
    #676
    TmecTaco79
    Adam
    Escondido,CA
    Looking at mine it kinda seems like the groves in the shroud need to be bigger so they slide over the black plastic that hold the projector lens in.
  17. Apr 26, 2011 at 8:30 PM
    #677
    Pingo
    North Pole, AK
    I should have the original gattlings since I ordered on day 1 and never got an email saying they weren't available or anything. I'm not sure what's goin on
  18. Apr 26, 2011 at 8:44 PM
    #678
    TacoDanny
    TacoDanny Well-Known Member
    OC, CA
    '10 4x4 Offroad
    King CO w/ res, Camburg UCAs, King Rears w/ res, Ironman Rear Leafs, CBI Rear Bumper w/ Swingout, KR Fab sliders, Ultragauge, Satoshi grill, Weathertech floor mats, DeMello 3 Hoop Front Bumper, AFE CAI Intake, Retrofitsource FX-R Projectors
    My gatling shrouds don't even cover all of the projector housing. I can see the bottom corners of the projector housings.
    nvm it looks like it is normal from the other retro pictures I saw.
  19. Apr 26, 2011 at 8:48 PM
    #679
    LouTaco
    LouTaco Well-Known Member
    Lou
    Des Moines, Iowa
    2018 T4R SR5 Premium
    try dremeling the inner collar part it may be hitting the four screws that hold the lens on so may have to notch the shroud a little , maybe? i have apollos and they fit good w/o trimming
  20. Apr 26, 2011 at 8:52 PM
    #680
    Kram925
    I am having some trouble trying to figure out where to rout the wire harness that came with the kit and where to mount it. Would anybody happen to have some pictures of how you mounted the ballasts and harness and routed the wires? any help is appreciated
    Thanks
Thread Status:
