HID Retrofit (FX-r Bixenon projectors) GB
Discussion in 'Group Buys' started by RacerAV, Apr 7, 2011.
Thread Status:
Not open for further replies.
  1. Sep 16, 2011 at 10:46 PM
    #981
    MRW
    MRW Well-Known Member
    Marco
    Sunny San Diego
    2006 DCSB PreRunner
    See my build page!
    This flickering only happens when I fire up the lights... Its not a flickering where the lights go in and out.. It's a flickering of the lights changing colors until it hits the right temperature and then it stays stable. And they both flicker independently but seem to get stable withing seconds of each other..
    Could this mean bad grounds?
  2. Sep 17, 2011 at 12:02 AM
    #982
    MRW
    Marco
    Sunny San Diego
    2006 DCSB PreRunner
    See my build page!
    I'm starting to believe its my grounds. Anyone have advice on where they grounded ech wire coming oit of each headlight? I believe the ground wires is only about 10 or so inches coming out the ballast
  3. Sep 17, 2011 at 3:06 AM
    #983
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Definitely sounds like you have some poor grounds... I grounded my ballasts using ground points for other components of the truck. Look for them. Make sure that you have good ground first, as that is the problems of many people
  4. Sep 17, 2011 at 11:37 AM
    #984
    MRW
    Marco
    Sunny San Diego
    2006 DCSB PreRunner
    See my build page!
    Thanks will do.. Did you extend the ground wires are was the lengtH that TRs provided long enough? I found a good ground, I think, in the passenger, but cant find a good one on the drivers side next to the headlight
    I mounted the blast like this so I only have about a foot to play with to find a good ground http://www.tacomaworld.com/gallery/showphoto.php/photo/116045/cat/500
  5. Sep 17, 2011 at 12:01 PM
    #985
    cummins6speed
    cummins6speed Well-Known Member
    '05 4Runner Limited Edition
    Custom extended travel 2.5" King RR coilovers, 1.25" Camburg uniball uppers, homebuilt tube bumper
    Just find the closest screw into the sheetmetal, remove it, sand the paint and put your ground there
  6. Sep 17, 2011 at 4:45 PM
    #986
    MRW
    Marco
    Sunny San Diego
    2006 DCSB PreRunner
    See my build page!
    So I double checked the grounds and sanded all the surface to bare metal and wired them back up but I am still getting a flickering... see this video for reference:
    http://imageshack.us/clip/my-videos/69/r92m.mp4/
    You will see slight flickering on the right and then a lot on the left (driver side).
    Does anyone have advice on what could be the problem? The flickering is intermittent and most prominent when I first start the truck.
    Here is a pic of the lights installed:
  7. Sep 17, 2011 at 4:52 PM
    #987
    memario1214
    Colton
    Missoula, MT
    Ooh, that's definitely a bulb issue. It appears that the bulbs are arcing, if ever so slightly... Did you touch your bulbs with your bare hands at any point? I would definitely get a hold of TRS and get it ironed out. Color shift is normal, color flicker is not.
  8. Sep 17, 2011 at 5:01 PM
    #988
    MRW
    Marco
    Sunny San Diego
    2006 DCSB PreRunner
    See my build page!
    Thanks.. Man thats a bummer.. I paid someone to do the retro and now I need t contact him to see if he touched the bulbs... These bulbs were actually from his kit. Long story short I had him use his brand new trs kit to get started on my retro while my brand new trs kit was in transit to him.
  9. Sep 17, 2011 at 5:10 PM
    #989
    memario1214
    Colton
    Missoula, MT
    Well... Your projectors look fine as far as your cutoff is concerned, so I am not worried about that. Is this guy local? If not, get your shit from him and see if you can't swap. You're the ones with projectors mounted already. You need working equipment worse than he does currently.
  10. Sep 17, 2011 at 5:24 PM
    #990
    MRW
    Marco
    Sunny San Diego
    2006 DCSB PreRunner
    See my build page!
    Actually a member here did the work. Everything looks awesome, I guess I just need to wait for his response so I can see whats going on. And no he is in another state. Pretty much I got a box from him with my retro lights completed and the bulbs were already inside the headlights. It was just a matter of me installing them.
  11. Sep 19, 2011 at 8:26 PM
    #991
    MRW
    Marco
    Sunny San Diego
    2006 DCSB PreRunner
    See my build page!
    Thanks for your help guys.. It most likely is a bulb issue so I will be getting this replaced ASAP, but here are two pics of the final outcome.. to see more pics click on my build link in my sig!
  12. Mar 6, 2012 at 7:30 AM
    #992
    Oury
    Oury Texas Taco
    Oury
    Austin, Tx
    07 TRD Offroad
    stuff and more stuff
    Oury - Kit 1; 35w ballast/bulbs; 5000K; Gatling Gun; Angel Eyes, H4/9003 Harness;depends on price
  13. Mar 6, 2012 at 8:09 AM
    #993
    Namyo
    Namyo -
  14. Mar 6, 2012 at 12:01 PM
    #994
    Cortland
    Cortland Well-Known Member
    Cortland
    California
    Clifford aka Big Red
    Camburg 4" Spindles, 5100's All Around, All-Pro 1.5" Leaf Pack, All-Pro U-Bolt Flip Kit, Avid Sliders, AFE Pro Dry Filter, Wicked Flow 18" Muffler
    Which shroud do you guys think would look the best with the H1 kit? Iris, E46-R, E55-R?
  15. Apr 26, 2012 at 1:08 PM
    #995
    Slesse
    Slesse Tacoma level 27
    Kyle
    Port Coquitlam
    08 Tacoma
    Pro Comp Rims;32" Duratrack Tires; OME heavy duty lift in rear; 2" spacer lift in front; custom raised bed in box; Lear canopy; grillcraft grill; Rosen Head unit; Trail gear sliders; Tinted windows all around; Intermittent Wipers; White LED dash; Deactivated seat belt buzzer; Blue Sea Fuse panel; BAMF light bar running 4 Lightforce 170's (2 HID); FX-R retro HID's 4300k, with amber halo's, BHLM with black reflector bowl; stealth mode; Fenix Hide-a-way flashers as DTRL's; VIAIR OBA kit with 2.5 gal tank; 14" Magnaflow stainless steel cat back exhaust; de-badged; Hybrid badge applied; seasonal 4wheel camper "Fleet"
    Let's see some pics of all those retro's. I want to do this but can't decide what shroud to go with. Everyone seems to go with Gatling Gun or Apollo. I like the look of the Apollo, but was also interested in the Iris. Also, I can't make up my mind about how much of the headlight to black out, if any.
  16. Jun 16, 2013 at 3:57 PM
    #996
    Taco89
    Taco89 Well-Known Member
    Nik
    Charlotte, NC
    2013 4x4 Super White DBL Cab TRD Sport
    any links for a fx-r retrofit write up??
  17. Jun 17, 2013 at 10:41 AM
    #997
    import roller
    import roller Vinyl Wrap installer
    Shawn
    San Diego, CA
    No truck
    the FX-Rs are not PNP projectors. There really isn't a writeup for projectors like these. you have to determine the best method to mount them and aim them based on how the inside of you headlight housing is designed.
  18. Dec 5, 2013 at 11:36 AM
    #998
    Taylorm1
    Taylorm1 Well-Known Member
    taylor
    Idaho
    05 tacoma trd
    2" lift, aftermarket stereo, duel exhaust, aftermarket headlights,
    Taylorm1: kit1, 35 watt ballast/bulb, 6000k, gatling 2.0, depends on price
Thread Status:
