Hid retrofit help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by brian.gonz, Sep 21, 2020.
  1. Sep 21, 2020 at 5:55 PM
    brian.gonz
    brian.gonz [OP] Well-Known Member
    Brian
    Manor, Texas
    Supercharged 2012 TRD Sport DC
    TRD Supercharger, Relentless Fab Stingray, TRD Pro Wheels, BFG, AMP Research Runners.
    So i bought my truck with retros which I dont know much about. Anyways a bulb went out so I got new ones. Tried connecting it and it wont light up? I tested the ballast and igniter and new bulbs on the working side and all 3 things work. Just not on the passenger side. Any tips on the next thing to test or do because I'm stuck I dont want to mess anything up and have to buy more parts than needed. Thanks in advance.
  2. Sep 21, 2020 at 6:07 PM
    Asianguywithatruk
    Asianguywithatruk Well-Known Member
    CenCal
    05 taco DCSB
    King RR coilovers Ironman leaf springs 17" scs sr8 jet black 285 75 17 Yokohama geolandar Demello front bumper Brute force rear bumper
    Swap ballast. See if that work then report back.
    *** after reading your post again. It sound like you moved the ballast, bulb and igniter from the non working passenger side to the driver side. This happen to me before and it was the controller that was bad. It’s a $35 dollar part you can get from Amazon.
  3. Sep 21, 2020 at 6:25 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Have you checked the fuse(s)
    There is one for each side (Right and Left / High and Low)
  4. Sep 21, 2020 at 6:48 PM
    brian.gonz
    Brian
    Manor, Texas
    Didnt check the fuses I will check that tomorrow and update my findings
    TnShooter likes this.
  5. Sep 22, 2020 at 8:50 AM
    Skynet Surfer
    Skynet Surfer Well-Known Member
    Dis
    15 DC v6 SR
    Hood struts Weathertech floor mats Roll n lock bed cover With custom Yakima rack over the bed Poploc tail gate Bed mat Retrofit source led fog lights Hitch and or 4 pin wiring Or just random small crap!
    Take a picture of the hid kit
  6. Sep 22, 2020 at 4:26 PM
    brian.gonz
    Brian
    Manor, Texas
    So I checked the fuses they are good. Checked for any disconnected wires or frayed wires that could cause a short and didnt see any. I'm stumped. Unless like @Asianguywithatruk said the controller is messed up and causing only one side to go out
