HID reverse lights with Instant on
Discussion in 'Lighting' started by xyourlocaldjx, Aug 9, 2012.
  1. Aug 9, 2012 at 11:48 PM
    xyourlocaldjx
    xyourlocaldjx [OP] Well-Known Member
    Saw this on another forum...
    Basically installs HIDS into his reverse lights and lightly bondo's the bulb into the socket. can probably use silicon or something to prevent moisture. anyone ever done this? Was going to install a billy light, but they're freakin expensive.
    http://tl.acurazine.com/forums/showthread.php?p=11802436#post11802436
  2. Aug 9, 2012 at 11:53 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    I just threw LED's in mine....
    :popcorn:
  3. Aug 10, 2012 at 12:03 AM
    xyourlocaldjx
    Are you able to flip them on while driving? And how bright are they?
    As far as aux lights.. I dont like mounting anything on the outside where people can just steal it. Thats why i mounted my hellas behind the grill.
  4. Aug 10, 2012 at 12:12 AM
    CayucosTacoma
    CayucosTacoma Just think outside the Yota
    San Luis Obispo/Santa Barbara CA
    1998 Tacoma, 4x4 5 Speed, V6
    Specs in the Build Thread
    LED are just plugged in directly to where your stock reverse lights would be, and automatically go on when you are in reverse. And they are pretty bright. Ill try to dig up a comparison picture
  5. Aug 10, 2012 at 12:15 AM
    CayucosTacoma
    I sense a Lowe's trip coming :)
  6. Aug 10, 2012 at 12:25 AM
    CayucosTacoma
    Yes that'd work. well you should let me know when you order a set ;)
    But here is the pic of the LED
  7. Aug 10, 2012 at 12:29 AM
    xyourlocaldjx
    dang.... I guess i'll go LED... MUCH cheaper. just need to figure out how to connect a switch to turn them on when i want.
    I ordered dome lights and the center one is nice and white but the two up front throw off like a light bluish color... not cool =(
  8. Aug 10, 2012 at 12:43 AM
    xyourlocaldjx
    and this is why i'm studying construction engineering and not electrical engineering lol.
  9. Aug 10, 2012 at 5:40 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    That's not electrical engineering, just basic automotive wiring.
    SPST = Single pole single throw switch. This is a basic switch that you can pick up at a local auto parts store.
    Diode = You said you're in construction so this is like a backflow preventor for electricity. It only allows electricity to flow through it in one direction preventing you from backfeeding a circuit.
