HID 'shake' solutions?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by rtw07, Feb 23, 2019.
  1. Feb 23, 2019 at 1:47 PM
    rtw07
    rtw07 [OP] Well-Known Member
    Myrtle Beach, SC
    2018 Tacoma TRD Sport
    I know this has been discussed heavily but has a solution every been found? I just sent my headlights off for the BHLM and I wonder if it's something that can be addressed while it's opened up. I've been running the Morimoto HID kit in the stock projectors and the 'shake' has gotten progressively worse with time.
  2. Feb 23, 2019 at 1:51 PM
    avi8or_co
    avi8or_co Well-Known Member
    2022 Lunar Rock TRD Sport
    Yep, solution found....If you’re going through the trouble of having your lights opened to do that, may as well have made for HID projectors dropped in too. That would be a solution.
    r1200gs4ok and rtw07[QUOTED][OP] like this.
  3. Feb 23, 2019 at 1:53 PM
    rtw07
    Myrtle Beach, SC
    An expensive solution but I'm leaning towards the RX350 swap. I haven't had any issues with the cutoff on the stock projectors but the 'shake' is obnoxious.
  4. Feb 23, 2019 at 1:54 PM
    patdeezy
    patdeezy Well-Known Member
    souLcaL
    '19 OR 4x4 SuperWhite DCSB
    watching thread
  5. Feb 23, 2019 at 1:59 PM
    Falconsfan
    Falconsfan Well-Known Member
    2017 sr dcsb v6 4x4 black
    I've run cheap Amazon kensun brand hid's in factory 2017 projectors and have no hid shake, or flicker. And cutoff and beam are both perfect for me.
    Gerdaland likes this.
  6. Feb 23, 2019 at 2:08 PM
    avi8or_co
    Out of curiosity, you use those with a battery relay or plugged straight into the ballast/igniter from the factory harness? Any wiring issues?Wondering if anybody running aftermarket hid had any issues doing that
  7. Feb 23, 2019 at 6:37 PM
    Falconsfan
    Honestly I don't remember but I think they are straight plug in, no relay, I know the ones in my Camry are straight plug in, I've used these hids in every vehicle I've had since my 2008 titan and never had any issues
  8. Feb 23, 2019 at 6:40 PM
    hyper15125
    hyper15125 Headlight Retrofitting Hobbyist Vendor
    NJ (609)
    Do the Rx350 swap and dont look back
    r1200gs4ok likes this.
  9. Feb 23, 2019 at 6:44 PM
    TFly
    TFly Well-Known Member
    Travis
    Richmond, VA
    2018 Cement DCSB OR
    For a year, I've been running HIDs that cost half of what Morimoto does, and I have zero shake whatsoever.
    Gerdaland and Flash1034 like this.
  10. Feb 23, 2019 at 7:44 PM
    Tacoma2020
    Tacoma2020 Well-Known Member
    Are the HID’s too hot and wearing down the O ring gaskets and such?
  11. Feb 24, 2019 at 11:51 AM
    rtw07
    Myrtle Beach, SC
    That’s kind of what I was thinking since it’s gotten worse with time. When I reached out to TRS about the issue, they seemed to think it was an issue with the projector assemblies in the Tacoma. I think I’m going to end up going with the RX350 retrofit to fix the issue.
  12. Feb 24, 2019 at 11:52 AM
    rtw07
    Myrtle Beach, SC
    I have a relay installed on my set up. It’s easy to run the cables and provides some relief that you won’t damage the factory wiring.
  13. Feb 24, 2019 at 11:54 AM
    Tacoma2020
    I have my doubts it is the assembly.
    What I would like to know is the temp the stock halogens produce versus the 35w HID.
    Surely someone has data on that.
  14. Feb 24, 2019 at 12:08 PM
    Boosted_Carrera
    Boosted_Carrera Well-Known Member
    Hawaii
    2018 TRD SPORT, 1996 911 Turbo
    Maybe...just maybe...the o-ring does get hot and flexes more when heated. Someone could take an o- ring to a auto shop and match the size to see if it remedies it *or* a double o-ring if there's room .
    As some have said their cheaper ones doesn't shake could have a larger /thicker o-ring so it may NOT be a housing issue.
    If this does fix the problem , get a o-ring from an engine shop since it resists all sorts of heat and liquids. If you can a Viton o-ring in that size, even better. These things have a range of 400deg.
    Just note...if it is a tight fit, rub a little Vaseline on the o-ring, don't get any on the bulbs! I only use Viton o-rings when I rebuild my engines. It has never failed.
