HID with daytime running lights question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by FastEd1500, Jan 5, 2010.
  1. Jan 5, 2010 at 2:35 PM
    FastEd1500
    FastEd1500 [OP] Member
    Ed
    Ft Lauderdale
    2010 Tacoma
    I ordered a set of HIDs for my 2010 taco, i heard that there will be issues with the hid flickering because of the daytime running lights... Is this true? Or is there a fix.... Thanks
  2. Jan 5, 2010 at 3:27 PM
    rb11701
    rb11701 Oh yeah!
    Rob
    '09 Silver Streak TRD Off-Road
    Rear Suspension TSB, DTRL Mod, aFe Pro-Dry S,USA Spec PA15-TOY iPod Adapter, Dynolock Tailgate Lock, UltraGauge OBDII Scanner, CoverKing Neoprene Seat Covers
    Get a seperate relay that goes from the battery to the HIDS. Will never have a problem flickering unless your ballast goes to crap.
  3. Jan 5, 2010 at 3:27 PM
    rb11701
    rb11701 Oh yeah!
    Rob
    I forgot!
    Welcome to TW!
  4. Jan 5, 2010 at 3:33 PM
    Viet2100
    Viet2100 Well-Known Member
    Viet
    South Florida
    2016 Prius 4T
    I haven't heard of anything like this...
  5. Jan 5, 2010 at 4:19 PM
    steveh_2007
    steveh_2007 Pro Member
    NW Houston, TX
    07 TRD Sport PreRunner
    TRD Baja Suspension, FN Wheels BFD, TRD Cat-back Exhaust, TRD Cold Air Intake, TRD GrillCraft MX Grilles, FX-R 3.0 Bi-Xenon Retrofit with Osram CBI Bulbs, OEM Navigation/Bluetooth/Backup Camera Retrofit, WeatherTech Floorliners, Valentine One, ScanGuage II with custom V1/SGII BlendMount
    neither have I... I ran HIDs with my factory day-time running lights and didn't have any problems. You'll be fine.
  6. Jan 5, 2010 at 4:22 PM
    rb11701
    rb11701 Oh yeah!
    Rob
    Get the relay.
  7. Jan 5, 2010 at 4:29 PM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    First, definitely use a relay. Secondly, you shouldn't have flickering due to DRL's since the Taco's with DRL's are in the turn signals. You only run into issues on vehicles where DRL's are in the low beam lights.
  8. Jan 5, 2010 at 8:26 PM
    FastEd1500
    Ed
    Ft Lauderdale
    2010 Tacoma
    Thanks for the welcome and advise.. I will let you know how it goes.. Thanks!
  9. Jan 5, 2010 at 8:32 PM
    Crom
    Crom Outside
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Correct. DTRL are in the turn signals and not in the low beams.
  10. Jan 5, 2010 at 9:34 PM
    Viet2100
    Viet
    South Florida
    2016 Prius 4T
    Well the DTRL's are tied into the headlights. They go off when the headlights are on. So, there is a relay trigger for them. DTRL's are usually the high beam of vehicles that use a 2-bulb system. Toyota just did it a little differently and used the turn signal bulb. While others use separate LEDs.
  11. Jan 14, 2010 at 6:13 PM
    FastEd1500
    Ed
    Ft Lauderdale
    2010 Tacoma
    well i installed my hids, iam running 6k bulbs, do you think i need to worry about my fog lamps melting?? Any one have any problems like this..
  12. Jan 14, 2010 at 7:32 PM
    Crom
    Crom Outside
    Nick
    San Diego, CA
    Millions
    Ed, if you replaced your factory headlight bulb with HID bulbs and ballast, I don't think you need to worry about the fogs at all.
    The Fogs are powered with their own circuit and 15A fuse and were only connected to the headlights through the FR relay.
    The fog relay was there to sense voltage so you could only run the fogs when the low beams were active. Many of us have modified our fog relay to sense voltage from the ignition circuit. With the Anytime foglight modification we are able to run the fogs independent from all other circuits (assuming the ignition is on).
    I hope I understood your question and hope my answer helps.
