HID Xenon Group Buy Round 17! Ends 8/15/10
Discussion in 'Closed Group Buys' started by slimsdepot, Aug 1, 2010.
Thread Status:
Not open for further replies.
  1. Aug 28, 2010 at 6:38 PM
    #121
    opie1967
    opie1967 Active Member
    Alabama
    05 double cab pre runner trd sport
    And I never said anything about anyones finances all I want is a little help. So Chill and then BITE ME
  2. Aug 28, 2010 at 7:24 PM
    #122
    Gitmo
    Gitmo Well-Known Member
    Justin
    ^ Rofl. You look like an internet troll or at the very least one of those people who bitch about everything on youtube.
  3. Aug 28, 2010 at 7:31 PM
    #123
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    Ooooo, looks like we have an internet bully in our midst.
  4. Aug 28, 2010 at 7:49 PM
    #124
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Chill out people.
  5. Aug 28, 2010 at 8:30 PM
    #125
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    Slim is a very stand up guy and I would bet that when he reads all of this he will make it right. He has helped in out twice when he really didn't have to.
  6. Aug 29, 2010 at 4:50 AM
    #126
    StandingCow
    StandingCow Well-Known Member
    NJ
    09 SR5 4x4 V6 access cab
    Ah ok, I haven't done the install yet, I thought that piece might have come with it.
  7. Aug 29, 2010 at 6:35 AM
    #127
    StandingCow
    NJ
    It's easy to take text in the wrong tone, but the "BITE ME" comments didn't help. :)
    I am not sure that other people take things wrong, I think you need to take a look at how you write and say things.
  8. Aug 29, 2010 at 8:10 AM
    #128
    opie1967
    Alabama
    I am over it let it go. But all I did was quote what it says by his user name, Just let it go man.
  9. Aug 29, 2010 at 9:24 AM
    #129
    Twirlin
    Twirlin Nature just gets the blow-by
    WI
    '10 TRD Sport Mag Grey
    the whole reason for me posting was to get a feel for if other people had the same issue with the bulb not fitting in the opening.
    when I first matched up the stock bulb with the HID I noticed the tab location to be wrong. After I had a second pair of eyes look at the situation, he noticed that the base of the bulb (circular part with the O-ring) was larger in diameter than the opening in the fog housing. This is a big problem because since there is a O-ring, it's supposed to fit pretty exact. I just want to make Slim aware of it and if anyone else has the same issue, please post. I'd hate for this to be an ongoing issue in production. I thought it was just a different fog housing, but when Opie with a 2005 had the same problem I have with my 2010, it makes me wonder.
    Get back to us when you can Slim.
  10. Aug 29, 2010 at 11:23 AM
    #130
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    That is the perfect reason for making such post. I'd bet slim hasn't noticed this yet. Have you sent him a Pm? He may get those notices in his email.
  11. Aug 29, 2010 at 6:41 PM
    #131
    Twirlin
    WI
    I have contacted him via 4 different ways. Just waiting for a response.
  12. Aug 29, 2010 at 7:57 PM
    #132
    slimsdepot
    slimsdepot [OP] slimsdepot.com
    SoCal
    08 PreRunner
    Just an FYI to all these posts after my most recent post. I usually get an email notification to the replies to my threads but sometimes they don't come through. I just noticed all these replies tonight after speaking with Twirlin on the phone about his bulbs. If you have a problem please PM me so that I can address each and every one of you guys.
    As for those with bulbs that are a little tough getting in the housings. Some trucks I've noticed need to use a little elbow grease to get them in as for others they just slip right in. Try that before calling it quits.
    For those with the bulbs not turning on in the fogs. This is because some fog light stock wiring is weak and needs to be plugged directly into the ballast bypassing the connection on the bulb itself. There will now be 2 connections not being used on the bulb which you can just connect to each other. If this does not make sense PM me and I will explain.
    Like humanoid said I do have a life outside of tacomaworld and usually I can get everyone an answer within the day you leave a response. But I have been in the process of moving and as anyone that has previously moved knows its a nightmare...
  13. Aug 30, 2010 at 5:45 AM
    #133
    Twirlin
    WI
    thanks for taking care of me slim, I'll let you know how it goes.
  14. Aug 31, 2010 at 4:08 PM
    #134
    Taco2K10
    Taco2K10 All OEM All Japanese All The Time!
    Kelly
    Chilliwack, B.C.
    2010 2.7 5spd 4x4 AC SR5
    3K HID Foglights, Husky Liner mats, Autoventshade Ventvisors and Bugdeflector, OE Toyota Class III Hitch and OE 4 Wire Trailer Harness,
    arrived safe and sound today Paul, Thank You Sir!
  15. Aug 31, 2010 at 8:59 PM
    #135
    slimsdepot
    SoCal
    08 PreRunner
    You are very welcome! Enjoy! :)
  16. Sep 1, 2010 at 6:57 AM
    #136
    Twirlin
    WI
    has anyone else had this issue in the most recent GB? I'm waiting for replacement bulbs and will report back. I know opie had an issue but took it into his own hands and I don't want to modify anything. Should be plug and play.
  17. Sep 1, 2010 at 2:27 PM
    #137
    opie1967
    Alabama
    I did not even get offered replacement bulbs?
  18. Sep 1, 2010 at 2:58 PM
    #138
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    everyone relax paul is very helpful and like posted before has a life outside of here, he will take take of the problem he's legit.
  19. Sep 1, 2010 at 3:38 PM
    #139
    Taco2K10
    Kelly
    Chilliwack, B.C.
    I noticed very slight tightness to get em engaged into the housing... very minimal force was needed... yoiu kinda have to tip them in at first... nothing major.... i could see by the design of the back of the oem housings how the could distort, they dont have much plastic at all where the tabs engage.... that said this does allow for some give when they dont just drop in... I have the housing removed for wet sanding/polishing that may make it a tad easier as well...
  20. Sep 2, 2010 at 5:50 AM
    #140
    Twirlin
    WI
    alright ladies and gentlemen, my problem has been fixed and I'll tell you why.
    Paul sent me new bulbs. The new bulbs were noticeably different from the original bulbs. The tabs were located correctly on the new ones and the base diameter of the bulb miked at 19.65mm as opposed to 22mm on the old ones. The tightness that opie was experiencing was legit because the bulb that he and I were sent were incorrect. Might not have even been an H10 for all I know. All I know is that the new bulb WAS an H10 (said 9005 right on the bulb base).
    Thanks for making it right Paul.
Thread Status:
