HID Xenon Install Help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by flattire, Dec 20, 2010.
  1. Dec 20, 2010 at 5:58 PM
    flattire
    flattire [OP] Spending my beer money...
    North East
    4x4 SR5
    K&N Cold Air Intake, Lund Genesis Tri-Fold Tonneau, WeatherTech DigitalFit Liners F&R, WeatherTech Window Deflectors, Pioneer AVH-P4200DVD, Pioneer GM-D9500F, Pioneer TS-D1720C, Pioneer TS-D1702R, Pioneer GM-D7400M, JL audio 8w3v3-4, RAAMmat BXT II
    Hello all,
    I installed my HID headlights as per Link and now have the pax side light working intermittently. Does anyone have any ideas what might be the issue. The grounds seem to be good and all the connections seem to be correct. When I turn the lights on, sometimes it comes on and sometimes it doesn't. When on it stays on and both high and low works. Drivers side works without issue...
    Is the ballast bad?
    Relay bad?
  2. Dec 20, 2010 at 6:30 PM
    Dbl Taco
    Dbl Taco Hard Taco
    Virginia Beach,Va
    2013 X-Runner Supercharged
    Urd intake Urd stealth pulley Djm 3/4 DTLT headers Urd o2 sim Urd trac bar Afe 3" cat back Xii performance stock coils
    sounds like a bad ground if your not at battery and are under a bolt make sure u scuff the paint to expose the metal and check all your connections or swap ballast from pass to drivers side.
  3. Dec 21, 2010 at 6:56 AM
    flattire
    North East
    4x4 SR5
    Well, it works now. Just went out this morning and all seems to be good. I think I'll go back and check the grounds just in case that was the issue.
    On to the fog lights...
    Thanks for the help!
  4. Dec 21, 2010 at 8:28 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    If the issue continues, try switching the ballasts to the opposite side of the truck. If the opposite light then flickers, there's your problem.
  5. Dec 21, 2010 at 2:15 PM
    flattire
    North East
    4x4 SR5
    Yep, bad ballast.
    Swapped with the other ballast and the same thing happens. Light comes on sometimes and flickers when it starts if it does come on.
  6. Dec 21, 2010 at 2:40 PM
    KPT
    09 Prerunner
    Shoot slim a pm and he'll take care of you.
