Hidden light bar.
Discussion in 'Lighting' started by taintedtattoo, Mar 26, 2024.
  1. Mar 26, 2024 at 4:56 AM
    taintedtattoo
    taintedtattoo [OP] Member
    For those who installed a behind the grill hidden light bar, how much has the grill distorted or ruined the light output?
  2. Mar 26, 2024 at 9:18 AM
    Toy_Runner
    Toy_Runner Well-Known Member
    99 4Runner SR5
    3" OME lift, heavy coils f/r 3/16" steel skids Modified Coastal Offroad diy bumper 5spd swap ('98 donor)
    I'd got a pairbof SS5's behind my grille currently. I wired them up prior to install, took them on a country road, put on in the mount behind the grille and held the other in front of it. Visually it's a pretty big impsct, I'd guess 50% or so of the output is blocked. Beam pattern is much fuzzier. Also depends on what grille you have, but even something like an aftermarket grille with a wire mesh is going to block 20%+ of the light. I would attempt to mount the lights cantilevered forward/flush with the outside of the grille and trim the grille to fit if I was doing this long term. But this is only until I get my bumper mounted up.
  3. Mar 26, 2024 at 9:47 AM
    jackn7
    jackn7 Old Man Tan Taco
    Art
    So Cal
    2008 DCLB 4x4
    Just some stuff...
    I’m running a light bar mounted behind the grill on my second gen. Not sure how much is blocked because I never ran it in front of it, but I do know that there is plenty of light going forward, but as expected the sides are definitely cut off. Still, it works great paired with a set of ditch lights and fog lights.
