Hidden light bar
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Korby, May 31, 2024.
  1. May 31, 2024 at 5:10 AM
    Korby
    Korby [OP] Well-Known Member
    Freeport PA
    2017 Magnetic Grey Tacoma TRD Sport
    I bought a nilight light bar with there wiring harness. I have used the nilight light bars in the past. I haven't had a problem with them.
    My question, with their harness it came with a switch wired for it. It can be unplugged but I'm not sure how to put the new plug I have to the harness.
    Here is the harness and switch I got. I'll get pictures when I get home of the instructions on the harness
    Nilight 10014W LED Light Bar Wiring Harness Kit 14AWG Heavy Duty 12V 5Pin Rocker Laser On Off Waterproof Switch Power Relay Blade Fuse-1 Lead, 2 Years Warranty https://www.amazon.com/dp/B074GWMRGD
    CH4X4 Push Switch for Toyota Tacoma 3rd Gen 12V 3Amp - Led Light Bar Symbol 2 - Blue LED https://www.amazon.com/dp/B01M3VX73R
  2. May 31, 2024 at 5:16 AM
    abou824
    abou824 Well-Known Member
    Aidan
    Central PA
    '21 TRDOR Army Green 6MT, '13 Lexus RX350
    TRD Lift (Toyota 5100's) LT265/75 AT4W Method MR305 16x8 Bronze ARB Diff Breather Subaru Tweeters Garmin Dash Cam Clutch accumulator delete plate Vibration dampers on MT driveshaft shield
    Have you looked at the second to last picture on the CH4X4 switch Amazon listing? Explains the pinout there.
  3. May 31, 2024 at 5:33 AM
    Korby
    Freeport PA
    I must have missed that! Thanks
    abou824[QUOTED] likes this.
  4. May 31, 2024 at 5:34 AM
    abou824
    Aidan
    Central PA
    :thumbsup:
