Hidden winch? 1998-2000 Bumper
Discussion in '1st Gen. Tacomas (1995-2004)' started by BradyG, Dec 16, 2015.
  1. Dec 16, 2015 at 7:14 PM
    BradyG
    BradyG [OP] Member
    Brady
    Colorado
    SR5 v6 TRD 4x4 EXTcab
    Front (ToyTech coilovers) Eibach racing coil Bilstein Shock One inch diff drop Rear ToyTech add-a-leaf
    I know that a hidden winch wont completely fit in the bumper of a 1998-2000 Tacoma but I was hoping someone had attempted it and if so how much did they have to cut away and what did their mounts look like?
    any help would be great thanks!
  2. Dec 18, 2015 at 6:22 PM
    knuckleduster271
    knuckleduster271 Well-Known Member
    Baron Longrod Von Hug€nschlong
    ohio
    98 sr5 xtra cab
    881's, 5100's, soft 8's, elocker, matrix seats, smittybilt xrc8.
    Best i could do was a hidden front reciever\winch mount withthe 98-00 and it was hard enough getting it tucked behind all that plastic
  3. Dec 18, 2015 at 6:29 PM
    BradyG
    BradyG [OP] Member
    Brady
    Colorado
    Ok thank you. I would buy a winch bumper but being a student, budget is a major factor. I may just end up welding on what you did.
  4. Dec 18, 2015 at 6:52 PM
    knuckleduster271
    ohio
    98 sr5 xtra cab
    I opted to build my own because the store branded front recievers mounted way too low and severley hurt approach angles, the only mounting points were where the factory tow hook bolts are and they just seemed chincy for the $200 they cost.
    On the one i built it mounts to the factory tow hook points, to the bolt holes on the ends of the frame horns, horizontally through the fram and through the body mount above the frame.
    It was super stout, i winched a grand cherokee buried up to the rockers out of a river with it.
