Hide a key- emergency key dilemma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jethro, Jul 10, 2013.
  1. Jul 10, 2013 at 1:41 PM
    PaintDrinkingPete
    PaintDrinkingPete Well-Known Member
    NoVA
    2012 4x4 TRD Sport DCSB
    Problem is, if the chipped key is in the vehicle, then the car will still start with the non-chipped key...so why hide 2 keys?
    The OP's issue is that he doesn't have a spare fob to keep with the vehicle (though as has been mentioned, the chip is embedded in the key itself, not the fob, unless this has changed for 2013 models).
    Do 2013 models have key-less ignition? I'm not sure about that, but all 2012 models and below require the key to start the car, the fob is just for unlocking the doors.
    If you have the immobilizer system (not *all* Tacomas do), then the keys you were issued have a chip in them that's required to be present to start the vehicle as well.
    The chip is in the key, not the fob (again, at least on 2012 and below). I own a 2012 and also did not get a valet key.
    Yes.
  2. Jul 10, 2013 at 2:18 PM
    Okkine
    Okkine Well-Known Member
    Alberta
    1998 Tacoma, V6, Manual Transmission, 4x4
    I could be wrong, but isn't the grey key the master key, needed to program new keys into the trucks computer, not a valet key?
    EDIT: Meaning if you lose the grey key, you have to buy a whole new ignition system, rather than just a new key...
  3. Jul 10, 2013 at 2:36 PM
    CASTRATE
    CASTRATE Well-Known Member
    Gabe
    SW of Tulsa, OK
    2012 4x4 SR5 6spd
    If you store your fob somewhere, make sure to check the batteries on a regular basis. Baterries can explode. I had a weapon mounted light blow up in my gunsafe, starting a chemical fire, and causing a couple grand in damage and repairs.
  4. Jul 10, 2013 at 2:37 PM
    CASTRATE
    Gabe
    SW of Tulsa, OK
    2012 4x4 SR5 6spd
    What's all this 3 keys nonsense? I bought my 2012 brand new a year ago and recieved two keys and two fobs
  5. Jul 10, 2013 at 3:12 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Not true, at least for my '06. The stamped steel spare "door" key I have will NOT start the truck even with the transponder key right beside it, the transponder key actually has to be inserted in the ignition tumbler. The plain key will crank the engine just fine, but it will not start. Again, this is based on my experimenting with my '06.
  6. Jul 10, 2013 at 3:13 PM
    45acp
    45acp Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    I just keep a spare key in my wallet.
  7. Jul 10, 2013 at 3:47 PM
    YOTA LOVER
    YOTA LOVER Stay Calm, and Fire For Effect
    NH
    2011 MGM Tacoma DCLB SR5
    A slew of pricey stuff my wife hates me for.
    Hmmmm. Next time I go to the dealer I'll check it out.
  8. Jul 10, 2013 at 4:01 PM
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    My grey key has no chip. I was told that it was the valet key (which is kind of stupid because you can't even lock the glove). What I did get is the little tabs with the numbers etched on them so you can get new keys made.
  9. Jul 10, 2013 at 5:20 PM
    Okkine
    Alberta
    Hmm... interesting. I have the metal tag with the number too, but I was certain the dealer told me I needed the grey one to get a new key programmed. It was 4 and a half years ago though, so now I'm not so sure. I'm going to try my grey key tonight.
  10. Jul 10, 2013 at 5:30 PM
    YOTA LOVER
    NH
    I remember specifically the tag is necessary to avoid getting a whole new ignition. That tag has the code they need to program a new key.
  11. Jul 10, 2013 at 5:41 PM
    Teniente
    Teniente Well-Known Member
    Carson City, NV/Ensenada, Baja California, MX
    White 2006 SR5 DCSB 4x4
    I have one of these on every vehicle. They work great, been using them for years, never lost one:
    http://www.roadid.com/Common/LearnMore.aspx?PID=24
    Key goes inside, velcro strap wraps around wires or whatever, I tuck mine up under/inside the rear bumper.
  12. Jul 10, 2013 at 5:49 PM
    Kirk1589
    Kirk1589 Well-Known Member
    Dave
    Sticks-RI
    03 SR5 Off-Road
    Pasti-Dip Grille, K&N drop-in, Magnaflow 14", Custom tail light mod, Fog light mod, diff vent mod, Alpine Components, Sequoia JBL radio
    mines the magnet kind bolted someplace. 2nd gens just used 3M red doble stick take and mount it in the bed cubby
  13. Jul 10, 2013 at 6:06 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    My '08 came with 3. 2 keys/FOB's and a valet key.
  14. Jul 10, 2013 at 11:33 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    No, You are wrong. The Grey Key is the Valet key that they no longer issue. They can make a fully functional set of keys from the number tag that came with the key set.
  15. Jul 11, 2013 at 12:14 AM
    #35
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Totaled but still alive! Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers,m, Rear bumper 2.0, Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    1 key hidden inside the truck, and I put the fob inside the gas filler door while on the river/lake or whatever. No problems to date, (knock on wood).
  16. Jul 11, 2013 at 5:38 AM
    #36
    PaintDrinkingPete
    NoVA
    Apparently starting with the 2012s, they don't issue the grey valet keys anymore. My 2012 didn't come with one.
    Interesting...good to know. Obviously I've never tried it myself.
  17. Jul 11, 2013 at 5:49 AM
    #37
    PuffDr4gon
    PuffDr4gon Well-Known Member
    Joe
    Earth
    2013 TRD Sport 4.0
    Got mods?
    I have the hitch safe and love it. After loosing a key on a river after a long day of fly fishing then walking 2 hrs uphill to the cabin in pitch black; I swore I would never get locked out again!
    Overall design seems durable and it fits into the receiver nice and snug. It's very inconspicuous with the receiver cover on (which itself is snug and doesn't fall off). If you do buy the hitchsafe you will have to buy the extended locking pins for Toyota trucks as the receiver has an extra wrap of metal around it that leaves the regular locking pins too short.
    Here you can see the hitch safe at the bottom of my truck:
  18. Jul 11, 2013 at 6:19 AM
    #38
    Gregman
    Gregman Well-Known Member
    Freddy Beach, NB
    05 DC LB 4x4 SR5
    That's what I do. ;)
    And don't tell anyone about either key.
  19. Jul 11, 2013 at 6:38 AM
    #39
    belone12
    belone12 Well-Known Member
    Brian
    Long Island, NY
    06 Tacoma Double Cab 6spd TRD OR
    Bilstein 5100s, AAL, heated leather seats, Thule Rack, tow package, anytime foglight, Fold-a-cover
    I've been through the key fiasco as when I bought my '06 I was handed 1 key, nothing else. I immedialtey went to Home Depot to get 2 copies made so I could at least get into the truck if it was locked. After catching my breath from the quoted price for new transponder keys, (> $200), I took my chances at Home Depot with their programmed transponder key for $60. Worked so well I went back to get one for my Dad's Honda b/c he was also down to 1 key. Lastly, I bought a fob on ebay for like $10 and programmed it under 1 minute. So for about $75 total my comfort level was restored. I do a lot of water related activities so the key situation concerns me. If I go out, I leave the transponder inside with the door key hidden, telling the person i am with where it is.
    I can 100% vouch for the Home Depot key if anyone is looking for an affordable solution. I think it is only for Gen2 2006 - 2010 though, just double check. For some reason i can't open it but my "Ebay uncut transponder key" thread addresses this... The one i bought on ebay was junk.
    #39
  20. Jul 11, 2013 at 7:11 AM
    #40
    YOTA LOVER
    NH
    Any chance you wrote up a thread for programming the fob?
    #40
