Hide-a-key locations
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Veccster, Mar 2, 2009.
  1. Mar 2, 2009 at 3:10 PM
    RobK
    RobK Well-Known Member
    WI
    07 4x4 DC SR5 w/Tow
    TRD offroad/racing Intake, pioneer bluetooth headunit, wetsuit seat covers, weathertech floorliners, Bully side step bars, tailgate security mod, rear aux halogen lights, BHLM, Upper and Lower Grillcraft Grills, Relocated Horns, Mag-lite mounts, pop lock, truxedo tonneau, PUTCO window visors, spidertraxspacers f&r, , bilstein 5100s set @ 0 with stock coils in front and TSB AAL in rear w/ 5100s .
  2. Mar 2, 2009 at 3:16 PM
    smithrw
    smithrw Well-Known Member
    wichita, kansas
    09 tacoma sr5
    I put mine in a black magnetic key box then set it on top of the rear spring as far back as it will go. It's nearly impossible to see.
  3. Mar 2, 2009 at 3:16 PM
    Pster
    Pster Well-Known Member
    Charlotte, NC
    2006 Tacoma 4x4
    Bak Flip bed cover, shorty antenna, Peripheral iPod interface, Garmin 750 mount, add'l bed tie down rings, Westin nerf bars, hitch safe, tailgate lock, Ideal 1 3/4" turn-key clamp to secure tailgate from removal, Spare tire security cable, spare tire stainless air hose extender, Fumoto oil drain valve, Amp Research Bed X-Tender w/Schlage Cable Lock, bed mat, Redline hood struts
    I have the Hitch Safe installed and really like it. It is heavy and very well made. As noted earlier, you need a set of extended pins to attach it to the OEM Tacoma hitch as the hitch has a thicker wall to it. I put the OEM rubber hitch cover on the back of the hitch tube to keep out water and dust, works perfecto. I keep spare key, mini credit card, and some cash in the safe (in case I need a tow or gas and am broke....)
  4. Mar 2, 2009 at 3:18 PM
    RobK
    WI
    07 4x4 DC SR5 w/Tow
    I forgot about the pins. I wound up machining my own out of stainless. I also put the stock cap on the back of the hitch tube. works great!
  5. Mar 2, 2009 at 3:21 PM
    surfsupl
    surfsupl Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
    Well.......if I am ever on the run and need a truck, I know where some of you junior members are hiding your key! :devil:
  6. Mar 2, 2009 at 3:23 PM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    Watch who you're calling a jr member boy!
  7. Mar 2, 2009 at 4:28 PM
    surfsupl
    Gregg
    WestCoast
    Notice how it just mentioned junior members?
  8. Mar 2, 2009 at 4:43 PM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    You are forgiven my son.
  9. Nov 17, 2013 at 9:52 PM
    bluefoot
    bluefoot New Member
    Used to zip tie a spare key underneath. Now use a supra key safe mounted to truck since we use the hitch. Can change the combo anytime.
  10. Nov 17, 2013 at 10:39 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Except you just told everyone on an open forum that there's a Tacoma in Wichita with a black magnetic keybox on top of the rear spring as far back as it will go.....
    ....and the truck looks like this one
  11. Nov 17, 2013 at 10:44 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Those 4 wheel combo locks are extremely easy to "pick"
    There's no way in hell I would use a "Hitch Safe" or whatever they call it.
    I use a small Gunvault with that type of lock ONLY because it satisfies California's requirements for a "secure locking container"... not because I believe that it is a secure lock.
    As a kid, I had my bicycle stolen three times locked with that type of lock.
    It was a prank, I got it back every time, but it showed me that type of lock was worthless.
  12. Nov 17, 2013 at 11:21 PM
    Tacomaruss
    Tacomaruss Active Member
    Russ
    Leduc
    Alpine White 2013 TRD Trail Teams
    If you carry your phone around, buy an aftermarket remote keyless entry system (throw the remotes away) and add on a system (I have Drone) that allows you to remotely control your locks from anywhere in the world. As long as the truck is parked in an area with cell coverage it works. I can use my phone or the internet and control everything. Plus it alerts me to alarm triggers and or if the truck is moving.
  13. Nov 18, 2013 at 9:17 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    thats exactly what i did.... some bailing wire and electrical tape holds / hides it on the small body cross member right by the front inner corner of the gas tank.
  14. Nov 18, 2013 at 9:27 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    There are all kinds of places to hide a key. The rear leaf spring is nice.
  15. Nov 18, 2013 at 9:29 AM
    #35
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren bump stops, Crown braided/extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Sherpa Grand Teton/Crows nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights
    Do you really think that's a good idea on a public forum? :rolleyes: Just keep a spare in the truck and have the dealership make you a credit card key (only opens the door.)
  16. Nov 18, 2013 at 11:18 AM
    #36
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    the best hiding spot is the one you didnt talk to a bunch of internet strangers about on some forum. :D
  17. Nov 18, 2013 at 12:11 PM
    #37
    tomwilson74
    tomwilson74 Well-Known Member
    Tom
    West Virginia
    2020 TRD double cab OR
    OME 3” lift Mickey Thompson Classic III Wheels
    If you zip tie it, make sure you have a pocket knife to cut the zip tie.
  18. Nov 18, 2013 at 12:14 PM
    #38
    anders99
    anders99 The Sailing Member
    Matthew
    Penscola, FL
    (07 Base 4cyl 4x4 - RIP) -> 2018 4Runner SR5 Premuim
    Taco SOS Offroad Concepts hybrid front bumper Iggy Corp. Switch panel Famous Fab ditch lights and cb antenna mount Pioneer Appradio 2 Halo Led Headlights Led Taillights 3'' toytech spacer lift on front end Toytec AAL on rear AFE cold air intake 4Runner Stock
    Magnet key box under the drivers side door on the frame. I accidentally found one the previous owner put there. I have used it multiple times
  19. Nov 18, 2013 at 12:33 PM
    #39
    whahahajr
    whahahajr Lone Star Club
    jimbob
    New Braunfels, Tx
    07 Tacoma TRD
    Camburg Uniball UCA, ARB Front Bumper, TAG rear bumper, OME rear shocks, All Pro 3" leaf springs
    My bins above the wheel wells pop out and I think that would be a good spot to tape one on top of it.
    I once found a spare key that was behind the license plate. The bolt went threw it to the bumper. Not a bad idea seeing that you can take the bolts out with a coin if you had to.
