HIDs,Body lift, 5100s all kinds of questions
Discussion in '1st Gen. Tacomas (1995-2004)' started by newskooler, Dec 4, 2010.
  1. Dec 4, 2010 at 12:22 PM
    newskooler
    newskooler [OP] Well-Known Member
    Nick
    Lake Shastina,ca
    03 Tacoma x-cab TRD SR5
    881/5100 front, 5100 rear, AAL, K&N intake, Diff breather, grey wire mod, tg Low pro and sliders, Custom tube bumper, pinch weld mod, and more... smoked taillights, fabtech tire carrier, sony headunit, 12v always power mod, #70 unhappy clutch spring mod,
    background: i have an 03 x-cab trd sr5 with the 5100s and 881s with and 1.5 aal. ontop of that is a 3in body lift.grey wire, diff breather ect. diff drop and BPV on thier way.
    heres a few questions for you guys for few different things. i realize some of these have been answered and trust me i have done my fair share of searching. basically im trying to justify the cost and labor in these projects
    1. HIDs: what company do you suggest? i keep getting mixed reviews of DDM. i would like to get h4hi/low at 5000-6000k how do i know if/what kind of harness i need?error eliminators? adaptor cables?
    2. body lift removal. anybody got any tips? i have all the hardware from toyota wating for me to do it. i just really dont like the ugly gap and that my bed is like a sail when its windy
    3. with the body lift removed what will most likely be needed to be trimmed for fitment of 285/75r16with 4in bs? i know of the pinch welds and some plastic but i heard of having to trim body mounts?:eek:anybody have any write ups on that?
    4. has anybody ran the billes at the mid setting with 881s? if so hows the ride? im looking for about 1/2-1 more lift in the front. hows the angles of your cv?
    5. any suggested mods? im laid off for the winter and going stir crazy. dont say deck plate mod im kicking myself everyday for not getting the stock box from the guy i bought the truck from.:mad:
  2. Dec 4, 2010 at 12:28 PM
    TBK224
    TBK224 ~THE LIGHT GUY~ Vendor
    Tim
    Phoenix, AZ
    BADASS TACO
    6" Pro Comp Stage One Lift Kit and 35" Toyo Open Country M/T's riding on 18" XD Addict Wheels
    There are a lot of people on here who have trouble with DDM tuning HID kits from what I hear. If you would like a set, get in on my GB. My kit comes with everything you need and it's all plug n play with no cutting or splicing. My kits also come with a one year warranty. The link to the GB is in my sig.
  3. Dec 4, 2010 at 12:54 PM
    newskooler
    Nick
    Lake Shastina,ca
  4. Dec 4, 2010 at 1:10 PM
    magog45
    magog45 Well-Known Member
    Canada, just south of Santa
    98 tacoma 4x4 extended cab
    5100's all around, 2.75 inch lift, polyurethane body mounts, gibson exhaust, variation of the deckplate mod, intake resonators removed 285-75-16 goodyear AT
    "2. body lift removal. anybody got any tips? i have all the hardware from toyota wating for me to do it. i just really dont like the ugly gap and that my bed is like a sail when its windy"
    I removed my 3 inch body lift this past summer, I did the box first then the cab.
    The box was pretty straight forward, I disconnected the gas filler neck then cut the hoses to the right length later. Four of the bolts are blind so its best to soak everything with lots of penetrating oil so you don't break them but on a newer truck shouldn't be much of a problem. I took off a filler piece that was above the rear bumper and with everything disconnected and unbolted I just knocked out the spacers, first one side then the other and settled the box down into its proper place and bolted it back together(make sure you get the right size bolts for the blind spots)
    The cab itself was more detailed but not too bad. I undid all the mounts and used wood blocks to replace the spacers, then I unbolted the radiator and removed the little extenders that came with the body lift kit and I unbolted the shifter arm for the automatic tranny right at the tranny, and spent a lot of time taking off the steering column extender as it was the wrong spline for the shaft. Once everything was disconnected I started lowering the cab one inch at a time by using smaller wooden blocks. At each step I check for anything binding anyplace and carefully squeezed the curlycues on the breaklines together as I when. Important thing is to go slow and check for anything binding or bending. The biggest problem was the connection from the steering column to the rack, the extended pieces that was on as I said was the wrong spline so I had to slowly hammer it off from the side then I had to find the proper one at the local scrapyard, you'll want to be careful when you line it up as well.
    So mostly its just being careful and taking your time but with the new polyurethane body mounts it even seems to ride better and certainly looks better
  5. Dec 4, 2010 at 1:20 PM
    '02TRD
    '02TRD Well-Known Member
    Portland, OR
    2002 Tacoma Xtra Cab 4x4 SR5 TRD
    Billstein 5100's & AAL, 285/75R16 Toyo Open Country M/Ts on Black 16x8 Raceline Renegades, Pro-Tech Toolbox, Wet Okole covers, K&N air filter, Tow package, Alpine digital media receiver, Kenwood Amp, Rockford Fosgate 10" sub, Cobra 75 hand held CB, front differential drop
    good decision on removing the body lift! rep
  6. Dec 4, 2010 at 1:40 PM
    kinkrider101
    kinkrider101 Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    Ddm tuning has a lifetime warrenty..and only a few people have had issues..many people are happy with the kit
  7. Dec 4, 2010 at 1:46 PM
    newskooler
    Nick
    Lake Shastina,ca
    just went with TBK224's GB save me the time of trying to figure out what i need.
  8. Dec 4, 2010 at 8:43 PM
    newskooler
    Nick
    Lake Shastina,ca
