HID's & Factory Warranty
Discussion in 'Lighting' started by Snoranger, Nov 13, 2011.
  1. Nov 13, 2011 at 1:30 PM
    Snoranger
    Snoranger [OP] Well-Known Member
    SW Washington
    Silver 2012 TX Pro
    Philips LED Headlights PIAA Xtreme White Fogs Block Heater 30% Tint Decals Removed
    Does anyone know for sure if by installing HID's if it will void the factory warranty?
  2. Nov 13, 2011 at 1:33 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    it will not...
    that being said this is assuming you didnt overload a cirruit or improplery wire it up
  3. Nov 13, 2011 at 1:37 PM
    onesixseven
    onesixseven Well-Known Member
    Tyler
    Santa Clarita California
    02 Prerunner SR5
    3.5" Kind Coilovers Total Chaos UCA's 31" BFG A/T's 8000k hi/lo HID kit Flowmaster Super 44 5% tint all around exterior LED's Deck Plate Mod bedlined flares debadged Full Fosgate/JL Audio Stereo
    i heard it voids any kind of warranty on the headlights. my buddy tried to take his truck in cuz the headlights were oxidizing, and they told him it was because had 55watt HID's in there that burn a hell of a lot hotter than stock. kinda sucks but arguing with the stealership is like :deadhorse:
  4. Nov 13, 2011 at 1:39 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    its possible......^^^^^
    havent happened to me and i have been running hids 55w for 2 years
  5. Nov 13, 2011 at 1:43 PM
    onesixseven
    Tyler
    02 Prerunner SR5
    i completely agree it is possible. just sucks anyways. then again HID's are intended for glass projectors so, unless u do a retrofit(for first gens) or buy some projectors, ur kinda SOL. what kelvin do u have?
  6. Nov 13, 2011 at 2:01 PM
    Snoranger
    SW Washington
    Silver 2012 TX Pro
  7. Nov 13, 2011 at 3:35 PM
    iroc409
    iroc409 Well-Known Member
    Washington
    A red one
    If the aftermarket part caused the failure, they will not warranty the damage (with pretty much everything).
    You could put some Osram 70/65W bulbs in there (1300/2000 lumens) instead of blinding everyone else on the road. :)
  8. Nov 13, 2011 at 3:37 PM
    AsianAnts
    AsianAnts just an AnT
    AnT
    Southern California (San Diego County)
    2011 PreRunner TRD Sport L/B Grey Metallic
    -Satoshi Grille Upper/Lower/Triangles -LED Map Lights, LED Dome Light, LED License Plate Lights -No front license -Wet Okole -Weather Techs (digi) -Running Boards -Bed Extender -AFE Cold Air Intake 2SI Dry Filter -Tailgate Hose-Clamp Mod, Tailgate washer Mod -Combi chain lock on bed extender -no chime w/ key in ignition & open door -Fog Light anytime -Slim Cubby's 3kHID fog -bumper plugs -keyhole plug -TRD license plate frame -combi-lock storage -rear TSB -window tint -camera mod -Painted radiator/engine covers -LS460 RetroFit -Bed Tie-Downs -LED Gauge Cluster, radio, clock and AC -Bed Mat -Extra DRings -Painted center console, radio unit, ac panel, overhead console.
    or do a proper retrofit and power it with 55w!!!!! LOL
  9. Nov 13, 2011 at 7:07 PM
    Snoranger
    SW Washington
    Silver 2012 TX Pro
    I've heard that the 55w HID's get too hot and cause damage to the lens and/or housing...
  10. Nov 13, 2011 at 7:15 PM
    cummins6speed
    cummins6speed Well-Known Member
    '05 4Runner Limited Edition
    Custom extended travel 2.5" King RR coilovers, 1.25" Camburg uniball uppers, homebuilt tube bumper
    Not unless it is the direct cause of a problem that would otherwise be covered
  11. Nov 13, 2011 at 7:16 PM
    cummins6speed
    The lenses and housings can take a bit of heat, 55w is fine
