HID's for Low or High beam?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by coveny91, Sep 27, 2010.
  1. Sep 27, 2010 at 7:00 PM
    coveny91
    coveny91 [OP] Member
    smoked tail lights, LED third brake light, projector headlights
    i bought some after market lights that have two H1 bulbs for high and low beam. i have been wanting to get some HID's but i dont really know much about them. i see that most people run them for their low beams. i was wondering if you can run them in your high beams. i want to have the HID's for the high beams so that way when it snows hard or there is bad fog i can still switch to low beams and be able to see. is the set up i want possible or common?
  2. Sep 27, 2010 at 7:02 PM
    Brunes
    Brunes abides.
    Rotorhead
    What Gen truck do you have??
    Anything is possible- but the more info we have about your truck the better we can answer the question.
  3. Sep 27, 2010 at 7:08 PM
    coveny91
    i have a 2005 double cab TRD
  4. Sep 27, 2010 at 7:34 PM
    808matt
    808matt Well-Known Member
    hawaii
    15 crew cab
    wait, you drive around w/ your high beams on and not your lows? your suppose to drive w/ low beams
  5. Sep 27, 2010 at 7:40 PM
    coveny91
    if your not supposed to drive with your high beams on, then what are they for? obviously you dont blind people with your highs. you switch to lows for on coming traffic.
  6. Sep 27, 2010 at 7:43 PM
    808matt
    hawaii
    15 crew cab
    why do you switch to low for oncoming traffic?
  7. Sep 27, 2010 at 8:17 PM
    meeestirg
    meeestirg Well-Known Member
    D15, CA
    HID's are supposed to be in your low beams. in our trucks our bulb does both. and the HID bulb wires to the low beam. if you have separate slots for low and high you can put them in both but its a waste to put them in the high since we drive with our low beams. i only use my high beams to flash slow drivers or people who cut me off. but its not good to flash HID's, they WILL die out very quick if you keep doing it.
  8. Sep 28, 2010 at 5:17 AM
    virgilus11
    virgilus11 Well-Known Member
    kearny, nj
    09 sr5
    TRD supercharger,EMU 884 springs, 90000 shocks, air bags rear and TSB with EMU shocks, grillcraft mesh, Relentless front bumper,Armology rear bumper, byxenon hid's retro ,undercover lid with bike rack on top, Kenwood dnx9140,TRD cover seats
    I did a retro fit and installed FX projectors. These,, have a shield that is been raised for Highs. The intensity does not change. There for, theoreticaly, the life of the bulb and (or) ballast should not be afected by frequent high-low changes.
  9. Sep 28, 2010 at 5:54 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    you only have one bulb. and its H4 size. there is a metal sheild that covers the bulb. for LOW beam the bulb is behind the shield. for HIGH beam the bulb rises up and shines over the top of the shield.
  10. Sep 28, 2010 at 5:55 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
  11. Sep 28, 2010 at 6:04 AM
    virgilus11
    kearny, nj
    09 sr5
    Thank you for the info. I knew about the bulb- I did the retro fit twice. I was reffering to his remark- quote-your hid will die quick if you flash. In some Hid's the flushing is not that detrimental.
    Thank you for the link. Instructiv.
  12. Sep 28, 2010 at 12:11 PM
    coveny91
    i know the stock headlights only have one bulb but i dont have the stock ones anymore. i have two seperate bulbs. one for high and one for low. i guess i didnt realize evryone drove with their low beams on. i drive with my highs on so i can see farther down the road.
