HIDs going out over big bumps
Discussion in 'Lighting' started by The 2TR FE, May 2, 2016.
  1. May 2, 2016 at 8:32 PM
    The 2TR FE
    The 2TR FE [OP] 4 Bangin'
    Ian
    NH
    14 Toyota Tacoma Regular Cab 4x4
    LC Engineering Pro Flow Cat back exhaust w/ Magnaflow muffler and resonator delete, BF GOODRICH A/T KO2 (32s) bunch of led lights (two sets of duallys and a generic 28" light bar) smittybilt light bar mount HPS Short Ram intake with K&N cone filter Undercover tonneau cover (repaired)
    Hey,
    I know there are a few topics about this but I need something directly related to my incident. So just recently my passenger side hid bulb goes out over hard bumps randomly. I have done some different things, wiggled wires checked connections done the works. I did bang the top of my headlight with my fist and got it to go out.
    So I started doing some basic things I moved the ground to a factory ground which involved me extending the ground wire.
    I recently installed a handful of off road lights, a set of duallys and a cheap 28 inch light bar recently. I have already had my Piaa driving lights installed and my first set of duallys installed before I installed my hids. So what I am saying is I have a lot of grounds and power wires all in one place
    what could it be, I am thinking power wires because there is a lot of connections stacked up, and the power wire for the hid doesn't fit properly on the power, and the fuse for the hid is out in the open a lot of dirt and stuff is starting to get around the fuse
    I have had the hids for only a couple of months and I couldn't imagine what it could be I have to clean up some of the connections and grounds so it looks nice I am kinda thinking I need a new battery to be honest
    Thanks for looking :)
  2. May 3, 2016 at 8:28 AM
    unlewser
    unlewser Well-Known Member
    Tempe, AZ
    try swapping ballasts from side to side, so you can isolate its not the ballast. Then try again with the bulbs. 1 variable at a time.
  3. May 4, 2016 at 10:20 AM
    The 2TR FE
    Ian
    NH
    I am going to try swapping bulbs and see what happens then.
  4. May 13, 2016 at 7:23 PM
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    Or relay
  5. May 15, 2016 at 3:08 PM
    The 2TR FE
    Ian
    NH
    Hey thanks for the info, I actually just contacted the company and they sent me a new hid kit, free of charge..
    Lucky me :cool:
  6. May 17, 2016 at 10:34 AM
    unlewser
    Tempe, AZ
    what company? give them some positive publicity for backing their product.
