HID's interfering with radio waves
Discussion in 'Technical Chat' started by 09_tacoma, Mar 6, 2011.
  1. Mar 6, 2011 at 5:50 PM
    xodeuce
    xodeuce mmmmmmbourbon.
    Alabama
    2004 UZJ100
    Keep in mind, an arc gives off RF as well. I would suspect that the bulbs in a housing not designed for them would have some interference properties as well.
  2. Mar 7, 2011 at 1:35 PM
    09_tacoma
    09_tacoma [OP] Forever at a crossroads
    Mylene
    North Pole
    09 Taco V6 4x4 DLCB TRD Sport
    Headlights, Exhaust, grill, Kings all around resi suspension. Camburg UCA's, Clarion double din
  3. Mar 16, 2011 at 9:30 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Large antenna mounted farther away (on the bed rails)?
  4. Mar 16, 2011 at 9:41 PM
    topgun155
    topgun155 Well-Known Member
    Zack
    Richmond, TX
    2018 F-150 5.0
    RIP to my 08 Prerunner DC
    Could you just cover the Ballast in foil. If it makes it any better then find some wire mesh and cover them in that. BTW many experiments are done in a feriday(sp) cage. It is a cage made of brass wire mesh which blocks almost all radio signal.
  5. Mar 16, 2011 at 10:20 PM
    kd8awe
    kd8awe Well-Known Member
    Rocky
    Ohio
    4x4 TRD Off Road
    Fog mod, 3" lift, ShoMe stobes, MicroLight LED Strobes, HiLift Jack, RCI 2950, Yaesu 8900r, 20% Tint, ScanGauge II, Weathertech Side Window Deflectors, *** New Mod's (parts on the way) *** U-Bolt flip kit. Tom Woods 1 Piece Double Cardan Drive Shaft. 3* Axel Shims
  6. Mar 17, 2011 at 10:08 AM
    09_tacoma
    Mylene
    North Pole
    Not something I'm willing to do, that would look stupid (IMO) and it would be too much trouble for what it's worth. But thanks for the suggestion.
    I'll have to read up on those, thanks!
  7. Mar 17, 2011 at 10:21 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    I to have the same issue when I turn on my fog light HID's. The Morimoto's I have for the headlights do not interfere at all though so only the fogs do it. I havent tried anything yet cause I dont listen to the radio very often but I would like to get the issue resolved cause it does get annoying.:eek:
  8. Mar 17, 2011 at 10:26 AM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    You should be fine with the mori ballasts cause thats what I have and they dont cause an issue at all. Also my previous set of HID's for my headlights did not cause any issues with the reception as well. For some reason its only the fogs.:eek:
  9. Mar 17, 2011 at 10:32 AM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Good to know, I might try this. Does it matter how much foil you use or no?
  10. Mar 17, 2011 at 8:00 PM
    t4daddy
    t4daddy Well-Known Member
    North Alabama
    2008 PreRunner Double Cab
    Mori's in some Hellas cause the same problem, none other HIDs do, (fogs, retro headlights). I just pop in a CD or DVD or hook up my iPhone. Radio around hear sucks anyways...
  11. Mar 18, 2011 at 5:41 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    I get this action with AM radio with my halo headlights with just parking light halos on. I have gen2 ccfl halos so they were plug-n-play. I did no wiring for them. My HID fogs without relay harness doesn't make it any worse. Just an AM thing, FM/CD/MP3/USB is unaffected.
  12. Mar 18, 2011 at 7:50 AM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Good to know!! Like I said, I'll have to try this when I get some free time. I will let you all know the results.;)
