HID's Problems
Discussion in 'Lighting' started by cstephan, Jul 31, 2012.
  1. Jul 31, 2012 at 6:31 AM
    cstephan
    cstephan [OP] Jack Of All - Master at none
    Hendersonville, Nc
    17 Taco TRDOR -DCSB- Gov. Controled Special
    Hold my BEER and WATCH THIS
    TW,
    Who else here, has had problems form the after markets HID's kit? I have the ones form SLIM and having high beam problems/balist problems. the relay is not kicking over. am I going to experence problems a few years from now? did i take ~ 170$ Original cost + (QTY 3)(10$ warranty part shipping to me). total cost 200$ and burn in the air? . All i want is this to last....
  2. Jul 31, 2012 at 7:07 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    I've had mine for years now, slim's first GB. I did have a few issues with my ballast, which slim took care of promptly. These issues occurred over a 2yr period. Ordered a set from slim for my brothers truck, arrived with a bad bulb, and again slim took care of it. Keep in mind I'm just listing the problems I have experienced over the course of what must be. Close to 5yrs. Most of the time trouble free operation was the norm.
  3. Jul 31, 2012 at 7:11 AM
    Hydrolai
    Hydrolai Well-Known Member
    Johnny
    friendswood
    trd off road 4x4
    Firestick NGP Uniden 520 PROXL BadaBling! 6k Hid Plasti-Dip Wheels/Badges Leds Bed Lights
    usually its the ebay ones were the ballast are pretty much fake. also have the slim ones and been fine. no problems here
  4. Jul 31, 2012 at 7:11 AM
    Hydrolai
    Johnny
    friendswood
    trd off road 4x4
    also if the relay doesnt kick over or fails after it was working normal maybe a loose wire ? have had that happen to me multiple times.
  5. Jul 31, 2012 at 7:25 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    I also don't have the newer slim ballast. Keep in mind I for a while was wheeling my truck, these ballast were wet and covered in mud at times. Always cleaned and never submerged.
  6. Jul 31, 2012 at 7:26 AM
    cstephan
    Hendersonville, Nc
    I have tested the harness, and the problem is in the relay.
  7. Jul 31, 2012 at 7:27 AM
    cstephan
    Hendersonville, Nc
    This is good to know, i hope once th ebugs get worked out, that is does last 10-15 years.
  8. Jul 31, 2012 at 7:31 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I've got a slim kit and it's worked great for the last 2+ years. I've got it on a motorcycle which means it cycles while the starter cranks and at idle they tend to flicker (this all means I'm fairly hard on the ballasts and they've held up fine).
  9. Jul 31, 2012 at 7:34 AM
    medic2230
    Murph
    Bama! Roll Tide
    I've had mine for almost 5 years now. I had a problem after 4 years with the lights wanting to turn on by themselves. I contacted Slim and ordered a new relay harness and all is good again. I had another set that the plug had a problem where the stock harness connected to it. Contacted Slim and he took care of it under warranty. That set was only a few months old. If you wash your engine or the relay is in a spot where it gets water on it it can get in there and short things out. The relay harness isn't waterproof so it has to be put somewhere it won't get a lot of water on it. I did notice that another company had a sealed harness but I wasn't sure if it would work on these lights so I never ordered it and just got another from Slim.
    Edit: I have slim ballasts on both sets.
