High Amperage Alternator/ largest battery
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Georgeth1022, Nov 3, 2021.
  1. Nov 3, 2021 at 9:46 PM
    Georgeth1022
    Georgeth1022 [OP] Well-Known Member
    Shaun
    West Hills CA
    2013 BAJA w/ too many mods
    Too many to list
    Looking to upgrade my stock alternator to a high amperage one, and also upgrade my battery to the largest/best one that will fit in the stock location. I have a lot of accessories to power, winch, compressor, and a shit ton of lights. What should I be looking at, and why?
  2. Nov 3, 2021 at 9:49 PM
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    i would first add up all the amps all your lights are and go with an alt that can handle that. you arnt going to power the winch off the alt so a larger battery would work well for that. however, i can say i run a stock size battery with lights and a winch with no issues.
    Roberto123 likes this.
  3. Nov 3, 2021 at 9:56 PM
    Wyckedan
    Wyckedan Well-Known Member
    Dan
    Woodinville WA
    2014 Stormtrooper AC 2009 Ducati Hypermotard 1100s.
    1 fully operational Death Star
    Triple P likes this.
  4. Nov 3, 2021 at 10:02 PM
    BalutTaco
    BalutTaco Moja_Przygoda
    2019 Cement Limo Trail Edition -> 2022 Magnetic Grey OR
    Bird nest engine bay.
    I would get your alternator tune as well. Did mine recently I'm running 27f AGM, my Alt charging at 14.3 -14.4v
  5. Nov 3, 2021 at 11:19 PM
    Georgeth1022
    Shaun
    West Hills CA
    Too many to list
    I’m currently running a stock size battery(Optima red top) and stock alternator. With no load on the battery it’s at 13.4. Battery is 5 years old. With all my lights on and AC, it drops to 12.2. My installer and good friend said that my truck could really use a higher amperage alternator and fresh larger battery.
  6. Nov 4, 2021 at 9:58 AM
    danojeno
    danojeno Well-Known Member
    Inland Empire, CA
    2017 Tacoma CCSBORMT Silver
    Elka 2.5DC Camburg UCA Deaver AAL 275/70/17 KO2s
    I believe you would be powering the winch off the alt. Just the battery would be toast VERY quick while winching. This is why I'm looking to upgrade from my non-tow package alt, because even with a big battery, the winch is going to need that alt. Am I wrong with this thinking?
  7. Nov 4, 2021 at 10:16 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    You need to weigh the pros / cons.
    A bigger battery means a lot more weight, which these trucks do not like in the front. More prone to cracking the core support. Also, the biggest amperage draw by far will be winching. A winch draws enough that no alternator will be able to provide the full load, the battery will have to make up the rest of the load.
    That being said you'll never be winching with all your lights, compressor, and other accessories on. So manually switching off all the things that you dont need will help to reduce the overall load on the electrical system.
    If you are in need of a new battery, you could look at a group 27F I believe it is. Those should fit with with minimal mods (maybe just a new tray) and no need to extend the factory harness.
  8. Nov 4, 2021 at 12:01 PM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
    Don't forget to upgrade your "big 3" battery cable wiring. Them sparky pixies get all ornery on the stock small gauge cables.
    deanosaurus likes this.
  9. Nov 4, 2021 at 1:31 PM
    paranoid56
    San Diego
    14 double cab taco
    you would need a 500+ amp alt to do that. look at how much peak amp a winch can pull. your battery will be doing the heavy lifting. now if you are going to winch for hours a day you need to look at a PTO or a hydraulic winch like tow trucks use.
    treyus30 likes this.
  10. Nov 4, 2021 at 7:11 PM
    Georgeth1022
    Shaun
    West Hills CA
    Too many to list
    The reason I’m wanting to upgrade is I am experiencing some flickering of my Baja Designs lights when under a lot of load. Truck in gear, ac on, headlights and accessory lights on. I know that’s not normal. Multimeter is saying the amperage is low when all this is going on and the flickering happens.
  11. Nov 4, 2021 at 7:14 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    Batteries are around 70amp-hours at 500+ amps. Meaning you can winch for roughly 8 minutes off the battery straight.
  12. Nov 4, 2021 at 7:14 PM
    paranoid56
    San Diego
    14 double cab taco
    do they flicker with nothing else on? if no then you might try doing the "big 3" first. as its under 100 bucks (and would be needed for a alt upgrade anyways) this might cure that problem.
  13. Nov 4, 2021 at 7:22 PM
    Georgeth1022
    Shaun
    West Hills CA
    Too many to list
    They do not flicker when nothing else is on. The big 3? Explain exactly please
  14. Nov 4, 2021 at 7:27 PM
    paranoid56
    San Diego
    14 double cab taco
    you will want to upgrade the wire size for the pos coming off the alt, say something like 0ga, the ground off the case to the neg battery, same 0g then a wire from the neg battery to the frame/chassis. there are a few good write ups on here too.
  15. Nov 4, 2021 at 8:01 PM
    Waasheem
    Waasheem
    2007 xrunner
    Maybe you meant…voltage is low…. My opinion, if flickering happens, voltage and amperage are low, the alternator is probably weak. Your optima is probably crapping out. My last optima went south after 3 years, they aren’t as good as they used to be so do yourself a favor and don’t buy another.
    You can check the battery with a starter voltage drop test. If your meter has peak high and low voltage it’s easier. Set it to peak low dc volts connected to the battery with the engine off, you should see 12.5 or more. Start the engine, peak low should be well above 10.0. 10.5 or higher your good, 10.4-10-3 is a bit weak, less than that is definitely weak, less than 10.0 the battery is toast.
    If you have a dc amp clamp, you could see what the alternator is doing. Check it with the engine running, all lights, climate control, stereo all off. Then turn everything on loading it as hard as you can. After starting with everything off, you might see 5-10 amps tapering down as the battery recharges, it should taper down to maybe 3-5 amps. If it’s staying high you probably need a battery. When you turn everything on, amperage should go way up.
    Of course you know if your battery terminals are acid covered or posts are oxidized that needs to be corrected before testing.
  16. Nov 4, 2021 at 11:10 PM
    Leomania
    Leomania Well-Known Member
    Leo
    2011 Tacoma TRD Sport DCLB v6 4x4
    All stock, baby!
    It's a cable upgrade from the battery to the alternator and starter. Here's a writeup of one installation, and a thread where a member shows the prototype he made and later had for sale in the buy/sell/trade section.
  17. Nov 5, 2021 at 5:15 AM
    SR-71A
    Zack
    Southern Maine
    No offense man, but if you're trying to look cool while winching you're doing it wrong.
    As I said before and like others said, the winch is the highest demanding electrical load. 300-500 amps under full load all depending on your model of winch. Even if you had a brand new battery and upgraded alternator you should still be reducing 'non-essential' electrical and engine loads while winching. Aka turn off all your auxiliary lights, turn the AC off, and turn the HVAC blower off. Winch yourself out then start cleaning and packing up all your recovery gear. While you do that the truck will work on recharging the battery. Then you can turn your light bars back on and continue down the road
