HIGH and LOW beams at the Same Time!!
Discussion in 'Lighting' started by YotaDan, Jan 21, 2010.
  1. Jan 21, 2010 at 12:46 PM
    YotaDan
    YotaDan [OP] Dan
    Dan
    Oregon
    Check out this new Product that allows you to have your Low beams, High beams, and even you Fog lights all turn on at the same time for the ultimate in Lighting while using your factory lights!!
    Activates your low beams with your high beams for a huge increase in lighting performance!!
  2. Jan 21, 2010 at 12:51 PM
    mws4ua
    mws4ua I'll try being nicer if you try being smarter.
    Birmingham
    2018 GMC Sierra SLT Z71 4x4... Yeah yeah, I know.
    I'm having trouble viewing... can you post a bigger picture, please?
  3. Jan 21, 2010 at 12:54 PM
    YotaDan
    YotaDan [OP] Dan
    Dan
    Oregon
    Well I could try...........Ha! Not sure why it turned out so large. Oh, well.
  4. Jan 21, 2010 at 12:57 PM
    Jester243
    Jester243 all I wanted was a god dang picture of a hotdog...
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    some of this, a little of that
    man if people complain about fog lamps now...
  5. Jan 21, 2010 at 12:57 PM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    :laugh:
  6. Jan 21, 2010 at 1:23 PM
    TACONORM
    TACONORM Member
    NORM
    FL
    2010 TRD OR 4X4
    OHHH SHITT......thats funny as hell...."havin trouble viewing" I needed a good laugh after bustin my ass installing flex a lite. Thanx mws4ua
  7. Jan 21, 2010 at 3:47 PM
    xodeuce
    xodeuce mmmmmmbourbon.
    Alabama
    2004 UZJ100
    How much current would that draw with something like silverstars? Is it safe?
  8. Jan 21, 2010 at 3:54 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Silverstars are no more wattage than the OEM bulbs.
  9. Jan 21, 2010 at 3:56 PM
    Tsenekos
    Tsenekos Well-Known Member
    Greg
    Edmonton, CANADA
    2005 DC 4WD trd offroad
    Toytec 3" lift w coils,1.5 AAL,5100's all around,diff drop kit, axel shims,N-Fab nerf bars,bestop supertop,fog mod, weathertech mats
    is it legal to use high and low beams and even fogs at the sametime ???
  10. Jan 21, 2010 at 4:06 PM
    YotaDan
    YotaDan [OP] Dan
    Dan
    Oregon
    You wouldn't use them in town or when there is oncoming traffic. Same as usual. But when you are the only one on the road, on a backroad, or offroading it gives you full light output using all of your factory lights at once.
    Here's the link. They are available for the new trucks as well. Just haven't got the page built yet. If you are intrested, give us a call.
  11. Jan 21, 2010 at 4:12 PM
    xodeuce
    Alabama
    2004 UZJ100
    Yeah, but with incandescent bulbs wouldn't you be lighting both filaments at once drawing more current than either single? Just wondering how that'd work out, or if you'd end up melting something if you used them for a long time.
    With the PnP HID Bi-Xenon kits this would be kinda useless b/c there's a solenoid that moves a shield to activate the high / low beam.
  12. Jan 21, 2010 at 4:13 PM
    gusotto
    gusotto gusotto
    Gary
    Iowa
    2001 Tacoma 4X4 SR5 Extended Cab
    I'd guess it IS illegal.
    I know if I met a vehicle that didn't dim the high beams, He'd be getting high beam right back at him.
    This is a DUMB idea unless you are TOTALLY off the public roads.
  13. Jan 21, 2010 at 4:18 PM
    xodeuce
    Alabama
    2004 UZJ100
    Most of the time the law reads as no more than 4 forward lights. At least when I looked into putting fog lights on my old car. Something like an Acura Integra that has 4 lights, 2x high, 2x low obviously cannot have the fogs on with the high beams because that would be 6 forward lights. However, on my old Integra, the low beams would stay on with the high beams. If you had the factory fogs though, they'd shut off with the high beams on. It makes me wonder with the Tacoma if you have headlights and fog lights, that's still 4 forward lights regardless of high / low beam.
    Things that make you say, "hrmm?..."
  14. Jan 21, 2010 at 4:19 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yeah...You would be drawing more power, and getting the bulb hotter..
  15. Jan 21, 2010 at 4:23 PM
    YotaDan
    YotaDan [OP] Dan
    Dan
    Oregon
    Q: How does Brite Box affect bulb life?
    A: In millions of miles of on road testing (with thousands of Brite Boxes), we have found no negative effect on bulb life in vehicles that have had Brite Box installed. Top of Page
    Q: If I want more light, can I upgrade to higher output bulbs or headlights?
    A: Only if you choose your bulbs wisely. Bulbs that produce more light by simply putting higher wattage filaments into the bulb can cause major damage to your lighting system, even without a Brite Box installed. The reason is that the higher wattage filaments draw a lot more electrical current than the stock bulbs. This in turn can overload switches, wiring and / or headlight components. The only safe way to get more light without potential overloads is to use high tech bulbs that produce more light output with the same electrical draw as stock bulbs. These bulbs accomplish this with advanced bulb construction techniques. Some bulbs that fit this criteria are "Sylvania Silverstar" and "PIAA Platinum". Top of Page
    Q: How do brighter bulbs (without Brite Box installed) compare to using a Brite Box with standard bulbs?
    A: There is really no comparison. Honestly speaking the only advantage the brighter bulbs have over the Brite Box setup will be a slightly brighter low beam. The reason is that Brite Box does not affect (either negatively or positively) low beam only performance. Therefore the brighter bulbs will put out a little more light on low beam. When the high beams are engaged, the story changes. Yes, the brighter bulbs also produce more high beam light than stock - BUT the beam pattern does not cover the area directly in front of the vehicle. With Brite Box, there is an even carpet of light from directly in front of your vehicle to the farthest reach of the high beams. What would you rather have - A slightly brighter INFERIOR beam pattern (without Brite Box), or an even carpet of light that reaches from near to far. Remember, you can always upgrade to high tech bulbs with a Brite Box to maximize your headlight performance.
  16. Jan 21, 2010 at 4:28 PM
    Crom
    Nick
    San Diego, CA
    Millions
    The product must be for off-road use, but it doesn't state that on their website.
    Also, in certain cases too much light can be a bad thing. This is why you don't run fogs with the high beams at highway speeds:
    If you increase the foreground light, your pupils react to the bright, wide pool of light by constricting, which in turn substantially reduces your distance vision—especially since there's no increase in down-the-road distance light to go along with the increased foreground light. It's insidious, because high levels of foreground light give the illusion, the subjective impression, of comfort and security and "good lighting". http://www.danielsternlighting.com/tech/lights/fog_lamps/fog_lamps.html
  17. Jan 21, 2010 at 4:39 PM
    eordonez
    eordonez Living vicariously through mjp2
    Ed
    Chihuahua, Mexico
    TRD Sport Dcab 4x2 Black Sand Pearl
    OEM All Weather Mats, wheel locks, Toyota Silver Tube steps.....
    what I'm thinking is, they could melt the plastic? we've seen a couple of tacos here with melted headlights just for using the DRL.....
  18. Jan 21, 2010 at 5:17 PM
    YotaDan
    YotaDan [OP] Dan
    Dan
    Oregon
    You would have to talk to the Manufacturer about that issue. But all I can say is try it and I think you will like it.
  19. Jan 22, 2010 at 4:59 AM
    jlboudreau
    jlboudreau Member
    Clare
    06 TRD Sport
    Tauna Cover
    so when you put your high beams on all your lights come on but when u meet a car and you flick to low beam only your low beams and fog lights are on like they are regurlaly?
  20. Jan 24, 2010 at 12:09 AM
    uglygun
    uglygun Well-Known Member
    I've driven Fords most of my life. On Fords if you pull back on the light lever for the "flash" feature of the high beams. The way Ford wired this lever is that it will ignite high beams regardless of if the low beams are turned on or not.
    So yeah, if you pulled back the lever at night you had both high beams and low beams.
    Where am I going with this? When I was back in high school I used to use "Melt 'em mode" all the time when driving around. I learned that I would burn out bulbs FAST by doing this.
    I think you'll kill the bulbs before you kill the wiring harnesses.
    I would like to have it wired so that I could run fog lights with high beams though instead of being limited to low beams along with fog lights.
    Out in the country side I could see the high beams for reaching out far then having the fog lights fill in the gap along with the fill to the sides in front of the vehicle.
