high angle cv boots..
Discussion in '1st Gen. Tacomas (1995-2004)' started by Space Wrangler, Aug 10, 2010.
  1. Aug 13, 2010 at 10:02 AM
    Space Wrangler
    Space Wrangler [OP] Well-Known Member
    JCT
    Ga
    04 DC 4x4
    04 Tacoma 4x4 Double Cab SAW 2.0's Alcan's Ion 171 wheels 15x8 (-27mm bs) 32" BFG AT's
    that's exactly what i ended up doing. ...now i have 2 brand new axles that i have done the boot stretch mod on. ..and 2 spares that i'm going to put new inner boots on. ..4 axles for a little less that $200
    Digi- i've been running my co's at 1.5" since new. i never experienced any vibs or other negative effects other than the boots wearing. it's interesting how 2 similar vehicles can display different behaviors with similar mods. ..at any rate, my truck rides much better now. ..still firm, but also compliant when needed and no boot rub. ...i should have lowered them a long time ago.
  2. Aug 13, 2010 at 12:57 PM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    ya, so instead of breaking your axles that have a lifetime warranty and takes an hour to swap out, you'll blow up your diff. thats a great idea
  3. Apr 1, 2015 at 12:40 PM
    plamore
    plamore Well-Known Member
    Dave
    Fairfax, Virginia
    '18 TRD Offroad
    D-ring tow hitch insert (red)
    I just replaced my DS axel and added a 930 for the inner boot and left the stock outer boot. On the PS Axel I have the orange ORS high angle boot on the inner, but those things are 50$ a pop! The 930's are cheaper and it seems like they work just as well.
    As for the boot slide mod... I don't understand how that would help. I've heard of boots tearing from being stretched out too far from putting a lift on (like mine did), but never from being compressed to much. I guess I'll see how long my stock outers go before they wear through...
  4. Apr 1, 2015 at 2:30 PM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    Generally when you lift the "fins" on the boot are contacting each other due to a more extreme angle. The "fins" rub each other as the wheels spin causing wear and eventually tears. Sliding the boot puts the fins farther apart resulting in less rubbing, thus causing less tears.
    The boot slide mod isn't 100% fix, it just helps.
  5. Sep 16, 2017 at 2:53 PM
    FishTacoTruck
    FishTacoTruck Well-Known Member
    2012 Tacoma TRD Off-Road Spruce Mica
    lifetime axles from who? NAPA or similar?
  6. Nov 8, 2017 at 7:59 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    ONE option is O'Reilly. "Limited Lifetime Warranty" on their MasterPro CV - CV Axle Shaft
