High Angle Inner CV Boot with Boot Slide Mod
Discussion in '1st Gen. Tacomas (1995-2004)' started by akamrkent, Jul 19, 2015.
  1. Jul 19, 2015 at 7:38 PM
    akamrkent
    akamrkent [OP] Well-Known Member
    Kent
    San Jose
    2004 Black Tacoma TRD
    Homemade Bumper and Skid plate, OME lift, Powertrax auto locker(front dif) and a Leer Shell
    I'm going to share my documented experiment with you. I'm not a mechanic, but I can turn wrench!
    We're looking at the combining these two products:
    High Angle Inner CV from Off Road Solutions
    Duralast Gold/CV Axle (oem or other brands of axle would work.)Other side note is this axle does not use a tri-lobe tulip race. It is perfectly round and matches the boot.
    Using some tips from the Boot Slide Mod thread. Thanks @802YOTA
    Oh and two Hockey Pucks!
    If you don't know how to remove a CV axle watch this. https://youtu.be/1uNQTSm7wcM
    Tools you'll need:
    Basic shop tools! not gonna list them all...
    Depending on what kind of bands clamps you use, you'll need a band tensioning tool
    I ordered CV Boot Clamp Pliers for Ear type Clamps (those were the kind that came in the kit)
    Here's a side by side comparison to the stock boot. The High Angle Boots have two more baffles and are longer.
    Phase 1: Remove inner boot DO NOT CUT IT OFF!
    • Take the large band off.
    • Pull the Tulip race off the tulip bearings.
    • Clean up the some of the grease so you can access the retaining clip. Remove the retaining clip to slide the tulip bearing assembly off.
    • Remove the smaller boot clamp to slide the old boot off.
    • Clean up the grease and what not. If your CVs have a lot of miles on them or had dirt and water inside of them, I highly recommend a good cleaning in a bath of gasoline or parts cleaner.
    Phase 2: Preparing the Slide Stop Mod. There are a few different ways of doing this mod. I chose this method because of what parts I had available.
    • Cut the small side of the boot of maintaining the integrity of the piece so you can still seat the boot clamp.
    • Make an one inch spacer. I chose to add a spacers because the Duralast shaft has grooves to help seat the boot in place better. Adding the longer boot put me past all the grooves and I felt the added benefit of using a groove was worth adding a spacer. I made my spacer out of a Hockey Puck(cheap and tough as s#*t!).
    Phase 3: Put it back together! Make sure everything is clean. Don't want to get grease on stuff tell it's all together.
    • Slide the High Angle Boot down at least an inch and half past the last groove.
    • Slide your spacer on (if you are using one)
    • Slide the boot repurposed boot part down to the last groove and clamp it. (if you have grooves) If are not using a spacer, place this part at the desired riding position.
    • Slide the High Angle boot up snug against the spacer and clamped boot part and clamp it.
    • This is a good point to add half of your required grease. (the kit comes with grease) Try to keep the clamping surface clean.
    • Drop the Tulip bearing assembly on and set the retaining clip.
    • Before applying the bearing race, make sure the ring that mates against the diff seal is seated on the race. It's common for this to pop off while removing the axle from the diff. I also used a bit of loctite retaining compound to seat it, red will work to if you don't have the other.
    • Take note of where the bearings were wearing on the race ways. This gives you an idea of extension used while in use.
    • Put the remaining grease in the bearing race.
    • Seat the boot around the bearing race. This can be a pain, a flat head screw driver can help but be cautious not to damage the boot.
    • Once seated, before you clamp. Move the race up to the estimated extension recapping above. With the flat head or other tool, gently pull the boot away from the exterior of the race way to let the air pressure equalize. Otherwise your boot will collapse under suction.
    • Put you Boot clamp on. Tip: if you're not sure if your extension is right you can install the clamp just on the snug side and readjust the air pressure once installed. Then clamp it down good.
    On the above picture, my extension was short.
    On good extension and normal ride height, the baffles should barely touch at most. A little space is better.
    Thanks for reading. I'll post updates on durability and what not.
    Cheers
    Kent
  2. Aug 31, 2015 at 8:38 AM
    akamrkent
    Kent
    San Jose
    My boots still looking great! Just ran Slick Rock trail and everything looks solid. 1st time I haven't had to repair my CVs after a wheeling trip.
    zerotimeouts likes this.
  3. Aug 31, 2015 at 8:42 AM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    I am doing this to my 3rd gen 4runner.
    this is exactly what I needed.
  4. Dec 5, 2015 at 6:49 PM
    MatthewMay1
    MatthewMay1 I'm an amateur professional.
    Matthew
    Lone Star Republic
    Supercharged '01 TRD
  5. Dec 5, 2015 at 9:26 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    On the subject of the perfectly round tulip race, does the inside part still have the tri-lobe grooves for the bearings? I would consider buying these just for that part so I could use the high angle boots with it, and not have to use the OEM boot underneath to accomodate the odd shape)
  6. Dec 10, 2015 at 2:10 PM
    akamrkent
    Kent
    San Jose
    It does Have the tri-lobe grooves. Though I'm not sure if they are compatible with OEM tulips.
  7. Dec 12, 2015 at 4:15 AM
    98tacoma3rz
    98tacoma3rz Well-Known Member
    lancaster, pa
    2002 Double Cab Trd
    Great write up! Thanks for sharing! I just did that on my OEM CV's.
  8. Dec 14, 2015 at 8:14 AM
    akamrkent
    Kent
    San Jose
    Awesome! Glad it was helpful. Let me know how it works out with the trilobe bearing race. I've heard some people have a hard time getting a seal between the OEM boot cutout part and the Off Road Solutions boot. Did you by chance use any type of adhesive between the two parts?
  9. Dec 14, 2015 at 1:57 PM
    98tacoma3rz
    lancaster, pa
    2002 Double Cab Trd
    I haven't really driven it much since I did it. I didn't use any kind of adhesive. I guess I should have used some rtv or something. I got the boot clamp pretty stinkin tight. I guess we'll see!
  10. Dec 14, 2015 at 9:40 PM
    LikeABoss4x4
    LikeABoss4x4 Well-Known Member Vendor
    Sarah
    So Cal
    Nice write-up. We've always used these extended boots from and they look like a very similar product. We also sell some emergency boot covers made by PRP. They simply velcro around the boot in case it gets torn to keep the dirt out and mess down, but we've had a few people order them to run all the time as added protection. They make them for UTVs but I bet one of the 3 sizes will fit Tacomas: http://www.boss4x4.com/product-p/prp1-h27.htm
    akamrkent[OP] likes this.
  11. Mar 4, 2016 at 8:28 AM
    Red Baron
    Red Baron Let's call it livabetes, no more die
    Aaron
    Lost on a roundabout
    07 Radiant Red DCSB
    Things with metal, dog hair, more metal and lights
    @odomandr this is one that I saw for the boots, good shit man
  12. Apr 1, 2016 at 4:08 PM
    Dcsleeper408
    Dcsleeper408 Well-Known Member
    Mark
    San Jose
    2000 Sr5 xtra cab
    Fishing pole antenna
    sub'd need to this asap! would it be recommended to use new axles instead of my old axles? i think got maybe 100k on them.
  13. Apr 1, 2016 at 4:15 PM
    MTopp
    MTopp Professional bear handler
    05 SR5 4x4
    trifecta tonneau, pop n' lock, Depo black bezel headlights, mb 352 wheels, 265/75r16 cooper at3s, visors, colormatched 2011 grille with raptor LEDs, much LEDs in and out Future/wanted: black valence, hood scoop, catback, CAI, 285/75r16s, OMD leaf pack mod
    I'd get newer axles and then keep and service the old ones as spares
    Dcsleeper408[QUOTED] likes this.
  14. Apr 1, 2016 at 4:16 PM
    Dcsleeper408
    Mark
    San Jose
    2000 Sr5 xtra cab
    Right on! @MTopp appreciate the info!
    I'll probably get some OEM ones. had bad experience w/ duralast on my hondas
  15. Apr 1, 2016 at 4:26 PM
    MTopp
    05 SR5 4x4
    Yeah, oem is the only good option for Tacomas pretty much
  16. Apr 1, 2016 at 8:50 PM
    akamrkent
    Kent
    San Jose
    I'm using the duralast CVs. Though I just had to replace one. not because of the upper boot. But something inside the out joint was grinding and making it very stiff. I do like how the Duralast version had a cylinder for the inner joint, where as the OEM have a tri-cut making it harder to mate the boots.
  17. Dec 11, 2018 at 1:08 AM
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
    Reviving! Any updates on how its holding up. Plan on doing this this weekend
  18. Dec 11, 2018 at 11:17 AM
    pray4surf
    pray4surf Well-Known Member
    Rick
    Oceanside, CA
    98 PreRunner conv to 4x4
    F&R suspension, OBA, Custom bed rack, RTT, rear frame plates, 4x4 conversion from prerunner, many other
  19. Dec 11, 2018 at 12:51 PM
    BlackSportD
    BlackSportD Well-Known Member
    Los Angeles
    Icon/TC Mid travel, TRD S/C, PNP Greddy EMU, 625cc injectors, 2.2 pulley, Hayden tranny cooler, AEM wideband, TRD boost gauge.
    I think those are the boots that CVJ uses as well, and on my CVJ ''high angle' axles those ones have held up, it's their blue outer ones that failed really early, so I'd like to rebuild just the outer part using the OEM boot plus spacer mod. Would be interesting if this is the winning combo.
  20. Dec 11, 2018 at 4:14 PM
    DW85
    DW85 Dude.....
    Daniel
    Kentucky
    2001 XtraCab Tacoma TRD 4x4/2004 SR5 V6 4Runner
    Tacoma: Badlands basher front bumper Trail gear rear bumper Trail gear sliders OME Dakar’s OME 883 Coils Bilstein 5100s front Bilstein 5125s rear SPC Upper Control Arms Wheeler’s Extended brake lines ProComp 51 Series 15x8 3.5” BS 32x11.50x15 BFG KO2’s Honda CR-V windshield washer nozzles Hella 500FF fog lights Energy Suspension power steering rack bushings 4Runner: Hankook DynaPro ATM RF10 265/70r17’s TPMS Bypass mod RCI Skid Plate CBI Ditch light brackets 1.25” Wheel Spacers 2” Front Leveling Kit
    Would these be better boots or the same as the Porsche 930 boots?
