High beam indicator help!
Discussion in 'Technical Chat' started by xTACOMAx, Sep 21, 2016.
  1. Sep 21, 2016 at 8:00 AM
    xTACOMAx
    xTACOMAx [OP] Well-Known Member
    07 prerunner TSS
    Rough Country 3 inch lift, Aries bull bar, Spider headlights
    I bought a set of led headlight bulbs and the second time a got to actually drive with them on I noticed when I have my low beams on the high beam indicator will flicker/flash and the high beams do not come on when this happens has anyone had this problem before? Thanks!
  2. Sep 27, 2016 at 7:17 AM
    98tacoma27
    Ben
    Not Beech Creek
    Just bulbs? You didn't have to rewire or anything? What bulbs/kit?
    Put a stock one in the drivers side to see if it goes away, leave the pass side the LED. If it goes away, the LED bulb is "bleeding" through to the high side and illuminating the indicator in the combo meter.
    Or you could switch the pass and drivers side. Could be a bad bulb.
