high beam issue
Discussion in 'Lighting' started by HolyReptar, Mar 25, 2012.
  1. Mar 25, 2012 at 4:01 PM
    HolyReptar
    HolyReptar [OP] Well-Known Member
    Bry
    Thousand Oaks
    17 TRD Offroad 4x4
    Some Bolt ones here and there
    So I just noticed this today after a decent rain.
    My high beams are on constantly whether or not the switch is on.
    They don't flip. Can't figure out whats going on.
    They were working fine yesterday/last night.
    Wondering if I should pull the HiDs and see if that fixes it, anyone have any thoughts?
  2. Mar 25, 2012 at 6:22 PM
    Hii
    Hii Well-Known Member
    Try putting one of your stock bulbs in and see if the issue still exists
  3. Mar 25, 2012 at 8:40 PM
    joes06tacoma
    Joe
    Central Coast, CA
    X2
    It was awhile ago, but this happened to someone else that still had stock lights. He tapped the dimmer (?) relay in the underhood box with a screwdriver handle and it fixed it. Stuck relay contacts.
  4. Mar 26, 2012 at 2:38 AM
    Hook & Ladder
    Hook & Ladder Well-Known Member
    Maine
    16' TRD Tacoma
    The project @c4_fabrication-Sliders, HC bumper w/ swing out @kb_voodoo_fabrications-Bed rack @tepuitents-RTT @cali_raised_led-Fogs, ditch lights, bed stiffeners @prinsudesign-Roof rack @kingshocks-2.5 with adjuster @totalchaosfabrication-UCA @rcioffroad-diff skid plate Follow at @wicked_overland #nacrew
    I have had relays go bad and with the water in the air the water will get into the ballast, if they are cheep ones they will stay on or turn on randomly due to the poor seal. when its dry out take it all apart and dry/clean the connections then put it back together and make sure the connections are sealed and tight. after that i have no clue.
  5. Mar 26, 2012 at 8:51 AM
    HolyReptar
    Bry
    Thousand Oaks
    17 TRD Offroad 4x4
    So last night I went to pull them out and the High Beam issue was gone, however today on the way to work its right back to where it was. Going to pull them out after work and see if this happens with the regular bulbs....
    I know I should retro before HIDs but they're sooo pretty and not really blueeeee=P
    DJMtuning HID kit, bad reviews with customer service but I haven't had many complaints about the kit.
  6. Mar 26, 2012 at 9:15 AM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Hids in reflectors are stupid ugly. Can't complain at you while youre driving
