High beam question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by F1ashman, Apr 3, 2019.
  1. Apr 3, 2019 at 10:13 PM
    F1ashman
    F1ashman [OP] Member
    2017 Tacoma SR5 Sport 4 x 4
    Swapped better hi beam and lo beam bulbs in my 2017 TRD Sport and when checking their operation (parked in the driveway, motor running, parking brake set) noticed that when high beam is selected the lo beams stay on. Never noticed this before. Checked the owner's manual and no help. 2017 with projector lo beams are totally different from my 2007 TRD Sport. Am I missing something in "settings" or is this a safety upgrade? Did a search in the forums but did not find any info. Stumped. Appreciate any clarification. Thanx in advance.
  2. Apr 3, 2019 at 10:55 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Normal. 3rd Gens have separate high and low bulbs, allowing both to run simultaneously when using high beam. 2nd Gen has a single dual filament bulb (H4) that will quickly overheat if running both filaments at once, so only one filament is run at a time.
    F1ashman[QUOTED][OP], Chew and Yann like this.
  3. Apr 3, 2019 at 10:59 PM
    Yann
    Yann Well-Known Member
    Mick
    South Carolina
    98 Base I4 4x2 / 18 SR V6 4x4
    A/C Drain Pro Grille Intermittent Wipers Blacked out Wheels Blacked out Badges Gasshole Nfab Predator Bars Tweeter Upgrade Kicker Upgrade Morimoto Amber LED Fog Lights Meso fuse box Stage 1 taillights
    You're the perfect person to answer, lol.
    crashnburn80[QUOTED] likes this.
  4. Apr 4, 2019 at 6:50 AM
    F1ashman
    Thank you for the quick response. Appreciate the clarification.. The posts with info and tech data regarding headlights especially bulb recommendations have been very informative. Your in-depth analysis of the headlight problem/shortfalls made selection much easier instead of sorting thru the mfr hype and marketing promises. Driving at night with the recommended bulbs will make driving the country roads much safer. Thanx again.
    crashnburn80 likes this.
