High beam setup that best matches the rx350?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jbrentb, Jul 11, 2019.
  1. Jul 11, 2019 at 7:51 PM
    Jbrentb
    Jbrentb [OP] Well-Known Member
    Jake
    Wilmington NC
    Black 2016 Trd OR Dcsb
    17x9 mayhem prodigy’s with -6 offset duratrac 265/65-17, fox2.5 coil overs, fox 2.0 rear shocks, OME uca, custom vf tune, Urd spec-u exhaust, high flow catted dump tubes, mbrp muffler, S&B cai, Green lane off road skid and stump bumper, ss3 fogs, pro grill and tail lights, tint, led interior reverse and plate lights, bhlm retrofit HID headlights, Meso turn signals, gashole, and coin holder. hardtop on bed and mat. Blacked out meso everything!!!
    Getting the retrofit rx350 headlights and want to upgrade my stock high beam. Closest in color and needs to be plug and play. Don’t care if it’s hids of leds. Just want something simple and not crazy expensive and looks like the came color of the rx’s. I do know the retros have there own high beam. Thx
  2. Jul 11, 2019 at 11:14 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    2 things to consider:
    1) LEDs will lack focus and be a significant downgrade in high beam distance projection performance. You'll get more scatter but much less distance projection.
    2) HIDs high beams will have a delayed warm up time, which is really not ideal for high beams where you typically want instant on. You will not have the ability to flash your lights.
    WiscoPat, Taco_Coma and Chew like this.
  3. Jul 12, 2019 at 5:13 AM
    Jbrentb
    Jake
    Wilmington NC
    Thanks for the reply! Still don’t kno what to do!
  4. Jul 12, 2019 at 5:49 AM
    Taco_Coma
    Taco_Coma That's a lovely accent you have. New Jersey?
    South NJ
    2018 DCSB SR5
    Just get the brightest halogen bulb you can find and don’t worry about the color. Was it nightbreakers the brightest? I can’t remember
  5. Jul 12, 2019 at 7:08 AM
    18BRMTRDSportTaco
    18BRMTRDSportTaco Well-Known Member
    Sachse, Texas
    18 BRM TRDS DCSB
    TRD Pro SEMA wheels, 265/70/17 Falken Wild Peaks, OEM TRD Pro Grill, OEM Toyota Tundra LED foglights, Morimoto 5500K HID w/Hylux ballast, OEM Black Emblem Overlays.
    This^ you don’t drive with your high beams on all the time so color will not really matter.
    crashnburn80 likes this.
  6. Jul 12, 2019 at 8:16 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    In H9 bulbs, the stock German bulb is the brightest, short of possibly trying to find a 100w bulb and running heavy duty wiring and relays. You could run a blue coated H9 bulb to shift the color temp cooler, it won’t match but it will be closer. Nightbreakers and other performance bulbs are not available as an H9 as H9s are already optimized for performance.
    As others pointed out though, nobody sees the high beam to notice if the color temp matches the low beam or not.
  7. Jul 12, 2019 at 8:22 AM
    InSight Retrofits
    InSight Retrofits Closed
    I always preferred keeping the high beam halogen for instant on, and being slightly yellowish it has better output in rain/snow.
    You can get a whiter light such as sylvania ZXEs that will match it a little closer but it all depends on what color bulbs are in the Rx350s (4100k,4200k,4300k,4500k,5000k,5500k,6000k etc)
    Jbrentb[OP] likes this.
  8. Jul 12, 2019 at 8:23 AM
    WiscoPat
    WiscoPat One does not simply purchase a Ridgeline
    Pat
    Wisconsin
    2019 TRDOR Tacoma 1995 JDM 80 Series
    Mall Rated
    I recently retrofitted with the RX350 HID projectors and retained the stock h9 high beams.
    When taking them for a brief test in a rural area, the combination of the HID splitter and stock high beams (quad high beams essentially) is absolutely amazing, especially in locations with little or no ambient light. I felt as if the ISS could see me, just a rolling ball of light headed down the road.
    That said, I'm not concerned about looks, as the only point anyone would see the full high beam display is if I had to flash them in traffic. Just my .02, but I would suggest not worrying too much about it, as the output itself is top notch.
  9. Jul 12, 2019 at 8:35 AM
    Jbrentb
    Jake
    Wilmington NC
    Ok thanks everyone, I think I’ll just keep the halogen in the high beam. Maybe get a better bulbs.
  10. Jul 12, 2019 at 12:01 PM
    buntcake
    buntcake Well-Known Member
    Booboo
    2020 TRD OR Cement
    Keep in mind that with the RX350s you'll have a pair of already warmed up HIDs used with high beams, so having another pair of HIDs in the high beam spot isn't going to be that big of a deal. I have HIDs in both and it's pretty awesome. I also retrofitted in another projector for the high beam spot though, so YMMV
