High Beam switch bad?
Discussion in 'Technical Chat' started by JJ04TACO, Sep 21, 2016.
  1. Sep 21, 2016 at 3:21 PM
    JJ04TACO
    JJ04TACO [OP] Well-Known Member
    Jim
    Dallas
    04 White DC/TRD
    Fox 2.5 RR front, 2.0 RR rear from AccuTune Offroad, OME Dakar Leafs, Camburg Uniball UCA's, CBI Offroad Bolt on Sliders w/kickout, Scangauge II Uniden Bearcat 880 w/ 3' Firestick on CBI antenna mount B&M Trans Cooler
    High beams will work when I pull the stalk back to "flash", but push forward and it's a no go.
    Bad switch in the stalk? I'm pretty sure this isn't a fuse or relay. But then again, this is why we post up!
  2. Sep 22, 2016 at 5:04 AM
    98tacoma27
    Ben
    Not Beech Creek
    Had this happen in my 93 once. The contacts on the stalk itself were bad. I cleaned them with a nail file and it worked fine. Not sure if the 04 would be the same.
    Your relay sounds good since your highs do work.
  3. Sep 22, 2016 at 9:06 AM
    JJ04TACO
    Jim
    Dallas
    04 White DC/TRD
    Thanks, I'm good with mechanical, not electrical. I'm not afraid to try though...
  4. Sep 22, 2016 at 9:09 AM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    2011 Tacoma TRD OR 4x4 & 2021 Tundra SR5 DC 4x4
    AVS in-channel window visors Husky Mud Guards Husky Liners X-act Contour Floor Liners Cooper Discoverer AT3 LT- 265/75/16 C Toyota 16" Black TRD Trail Team Edition Wheels Truxedo Lo Pro Tonneau Cover OEM Bed mat OEM Running Boards Marathon custom fit seat covers Front window tint Rear Leaf Spring 4 Pack - TSB Front - 5100's with stock springs set at .85" Rear - 4600's
    Sounds like a classic case of low High Beam fluid :D.
    All kidding aside....sounds like the switch for sure.
  5. Sep 22, 2016 at 1:28 PM
    JJ04TACO
    Jim
    Dallas
    04 White DC/TRD
    Nah fluid was fine, I'll check the switch.
    But I'm leaning strongly towards a leaky beam gasket or a clogged photon collector.
    Sig45 likes this.
  6. Sep 23, 2016 at 4:46 AM
    98tacoma27
    Ben
    Not Beech Creek
    If you start getting into the muffler bearing...you've gone too far.
  7. Sep 28, 2016 at 1:12 AM
    JJ04TACO
    Jim
    Dallas
    04 White DC/TRD
    ;)Alright so I have a new multi function switch on order. $130 from Toyota Dallas.
    Question now is this. My Haynes says to remove the steering wheel, then to remove the column covers. Can I remove the covers w/o removing the wheel? It seems doable if I turn the wheel to expose the screws behind the wheel. It's a first gen. (04) Just in case my userid isn't clear.;)
  8. Sep 28, 2016 at 4:38 AM
    98tacoma27
    Ben
    Not Beech Creek
    I'm not sure. Try it and see what happens. Worst case, you have to take the wheel off.
  9. Sep 30, 2016 at 8:18 PM
    JJ04TACO
    Jim
    Dallas
    04 White DC/TRD
    Ok so I'm no regular Youtuber or anything but I found and fixed the problem with the switch, and made a few short videos to boot.
    A few things. It took all of 15 minutes and $130.00 for the switch from Toyota of Dallas. A dealer closer to me wanted 200 for the part and 200 in labor, and said it took an hour (maybe an hour minimum in labor). They did do a great job and had a great price for my timing belt and a ton of associated maintenance. But that was ridiculous.
    So here are the videos. I'm no Spielberg...
