High beams dont work
Discussion in 'Lighting' started by blabla13, Jan 19, 2009.
  1. Jan 19, 2009 at 10:23 PM
    blabla13
    blabla13 [OP] New Member
    96 SX 4x4
    I just bought a 96 tacoma 4x4 2.4L today. The low beams work just fine, however, the high beam light is always lit up on the dash and when I click to the high beams, nothing happens. The lights just stay the same. Has anyone had this problem?? I thought maybe it could be the dimmer switch...thanks!
  2. Jan 19, 2009 at 10:26 PM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2012 DCLB
    Grillcraft mx black upper and lower BHLM with Gloss black 265 70 17 bfg a/t center console light mini mag mounted in center console debadged bed lights 35W 5000k HID's
    first thing would be to check the fuses under the hood, there are 4 #10 fuses and the high beam ones could simply be burnt out, there should also be spare fuses in the fuse cover. don't put a wrong fuse in, replace with the proper fuses. mine are #10's on my 01. let us know!
    rab89
  3. Jan 19, 2009 at 10:29 PM
    blabla13
    96 SX 4x4
    great! thanks, for the tip. i will try that. i'll let you know what happens!
  4. Jan 20, 2009 at 2:13 AM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    12 Tundra TRDRW
    Nada, Zip, Zilch, Nothing
    Check your wiring as well. Both lights out at the same time would be a bit coincidental.
  5. Jan 20, 2009 at 5:44 PM
    blabla13
    96 SX 4x4
    so I checked the fuses and they are all good. i guess the next step is to check the wiring and dimmer switch....i appreciate everyone's help!
