High beams suddenly don't work
Discussion in '2nd Gen. Tacomas (2005-2015)' started by KPT, Feb 19, 2010.
  1. Feb 19, 2010 at 6:49 PM
    KPT
    KPT [OP] sees what you did there.
    09 Prerunner
    Just went to turn on my high beams and neither one of them are working. They worked fine yesterday.
    Checked the fuses for the left and right side high beams and they are fine. Also, I can hear the relay clicking when I engage the high beams.
    What could be causing this issue? Thanks.
  2. Feb 19, 2010 at 7:01 PM
    xSpyderguyx
    xSpyderguyx Well-Known Member
    Caleb
    Washinton State
    2001 3.4L v6 SR5
    s40 Flowmaster 33" Toyo M/T tires 16" P.A wheels 3" revteck Suspension lift
    Put the puzzle together :)
    Fuses work
    Relay works
    CHECK THE BULB:D
  3. Feb 19, 2010 at 7:03 PM
    KPT
    09 Prerunner
    I thought it would be impossible for them to both go out at the same time, but I checked anyway. Bulbs are fine.
  4. Feb 19, 2010 at 7:07 PM
    KPT
    09 Prerunner
    Actually let me take that back. The bulbs looked fine, but just be sure I just went out and put an old bulb I had laying around in. It works fine!
    What could possibly cause both high-beam bulbs to blow at the same time?
  5. Feb 19, 2010 at 7:13 PM
    KPT
    09 Prerunner
    The headlight bulbs I had in there were a "hyper white" color bulb.
    Just got to thinking, and I tried to put LED 194 blubs as my license pate lights, and both of those blew out within a week. What is the deal with my truck and aftermarket bulbs? This happen to anyone else?
  6. Feb 19, 2010 at 7:13 PM
    xSpyderguyx
    Caleb
    Washinton State
    2001 3.4L v6 SR5
    Ive heard stories that both bulbs go out at the same time, I think they are designed to do that so you change them at the same time? Im not sure...
    I remember my old driving school teacher told me she had a car and all of the bulbs would burn out withith a a few days of eachother
  7. Feb 19, 2010 at 9:23 PM
    btkicker
    btkicker Well-Known Member
    Denver
    '10 4x4 Reg Cab Manual
    Today's bulbs are made with strict tolerances, so yeah, blowing around the same time isn't a big deal.
  8. Feb 19, 2010 at 9:46 PM
    G-Sak
    G-Sak Well-Known Member
    PNW
    2005 TRD Offroad SR5 DC 6 speed
    FX-R Projector Retrofit with Apollo Shrouds, Digital HID 55 watt ballasts, D2S Philips 85122+ bulbs in the Winter and Digital HID 55w 5k bulbs in the summer, Bakflip G2, Pop N Lock, Tint, Grillcraft with PIAAs behind it, ScanguageII and a few audio/video upgrades.
    Before I got into retrofitting and HIDs I ran aftermarket halogen bulbs. The longest I ever had a set last was about 10 months so this is not surprising.
  9. Feb 19, 2010 at 9:49 PM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    After market, wildcat stuff is crap. Stick with the OEM, makes life much easier, less stressful.
  10. Feb 20, 2010 at 7:16 AM
    HankB
    HankB Well-Known Member
    Hank
    near Chicago
    06 Preruner TRD Off Road
    bone stock
    What's the possibility that one bulb blew earlier and you just didn't notice it until the other went?
    Anyway, they do have a limited life time and as others noted, with stricter manufacturing tolerances the lifetime of two bulbs could match.
    IAC, it seems that cold weather takes its toll on the bulbs. After getting our '06 this fall, I decided to replace both headlight bulbs to reduce the possibility that I'd be fumbling with a burned out bulb in freezing temps. I also replaced the low beams in our 'trix as they're on all of the time and we've put on over 40K miles since I last replaced them.
  11. Feb 20, 2010 at 7:25 AM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    This is why when one bulb burns out you should change both because the other one is usually not far behind if they were installed at the same time. It is rare these days that one bulb's lifespan would differ greatly from another.
  12. Feb 20, 2010 at 7:27 AM
    08TRD Sport
    08TRD Sport ROOTIN AROUND
    Joshua
    Augusta, Georgia
    10 5th Gen 4Runner
  13. Feb 20, 2010 at 8:12 AM
    dog tired
    dog tired Well-Known Member
    NE Ohio
    That happened to me once. both blew at the same time
    stranger things can happen I guess
  14. Feb 20, 2010 at 1:39 PM
    KPT
    09 Prerunner
    The bulbs were only in the truck for two weeks though. Seems too coincidental.
  15. Feb 20, 2010 at 2:48 PM
    dexterdog
    Oly WA
    2012 F150
    Well, I hope you didn't pay too much for them. Any sort of variance to a standard halogen bulb is risking life expectancy. I think you need to start looking towards an HID setup if you want that look.
