High Beams with Fog Lights
Discussion in '2nd Gen. Tacomas (2005-2015)' started by LP_Y_SO_SRS, Jul 6, 2015.
  1. Jul 6, 2015 at 10:59 AM
    LP_Y_SO_SRS
    LP_Y_SO_SRS [OP] Active Member
    Luis
    None yet
    Hello All,
    Is it possible to have the high beams and the fog lights at the same time?
    On my vehicle when i have the high beams off the fog lights turn off.
    **ive tried searching, the search function on this forum is very poor and returns unrelated articles probably due to searching peoples signatures.
    ***Google search also returned no results.
  2. Jul 6, 2015 at 11:02 AM
    moe2o4
    moe2o4 Well-Known Member
    Corey
    Pittsburgh PA
    2016 SR Silver 2.7L 5 Speed
    OME 3" Lift, 32" Tires, Lots of Mods!
    Hi,
    You can actually mod the fog lights to keep them on with your high beams, depending on what kind of truck you have.
    What type of truck do you have, year and so forth?
  3. Jul 6, 2015 at 11:04 AM
    Ostrichsak
    Ostrichsak Don't taze me bro!
    Jer
    Northern Colorado, USA
    Supercharged '10 Tacoma 4x4 TRD
    TRD Supercharger + too much stuff to list. Click sig pic
    Link in my sig is one easy way to keep the fog lights on w/your high beams. At least I think that's what you want since your description is a little confusing.
  4. Jul 6, 2015 at 11:06 AM
    Bagman
    Bagman Dental Floss Tycoon
    Area 51
    2023 4Runner SR5 Premium
    Search "fog light anytime mod". This mod will allow you to turn on your fog lights while your high-beams are on.
  5. Jul 6, 2015 at 11:10 AM
    LP_Y_SO_SRS
    Luis
    None yet
    Thank you, i did not know what to search.
    2013 Tacoma 4x4
  6. Jul 6, 2015 at 11:16 AM
    Ostrichsak
    Jer
    Fog light anytime mod will let you turn your fogs lights on... well... anytime. What he's describing is exactly what my version is: keeps the fogs from powering off when the high beams are on. They behave identical to factory otherwise.
  7. Jul 6, 2015 at 11:53 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    check the link in my signature for my foglight any time mod.
    If you want them to turn on and off with headlights but stay on with high beams look at the variation in post 39 of the same thread.
    Dj Suisav likes this.
  8. Feb 9, 2017 at 11:57 AM
    rarsop
    rarsop Member
    Bozeman, MT
    2017 TRD Pro Tacoma, Cement, 6-Speed
    HID, LED, SnugTop Rebel
    Any guidance on how to do this for a 3rd Gen?
  9. Feb 9, 2017 at 11:58 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    You can't.
    3rd gen fogs are ECU controlled.
    rarsop[QUOTED] likes this.
  10. Feb 9, 2017 at 12:02 PM
    rarsop
    rarsop Member
    Bozeman, MT
    Meaning it can't be changed? Or wired to run independent? Thanks for the help
  11. Feb 9, 2017 at 12:05 PM
    T4RFTMFW
    Just going off information others have posted.
    Anything can be re-wired, but as far as converting it like the second gen trucks - no dice, re-wiring to a switch seems to be the only option.
    ZachPrerunner likes this.
  12. Feb 9, 2017 at 12:07 PM
    ZachPrerunner
    ZachPrerunner Sometimes she goes, sometimes it doesn’t
    Southeast TN
    ‘07 TRD Offroad / ‘19 TRD Offroad 4x4
    Can be changed, but is more technical than the 2nd gens considering it's controlled by the ECU.
