High Beams work, low beams don't
Discussion in '1st Gen. Tacomas (1995-2004)' started by EricKrum, Apr 14, 2017.
  1. Aug 18, 2022 at 6:45 AM
    #41
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    You may get more traction in the 3rd Gen section. Completely different truck that the 1st Gen
    Dm93 likes this.
  2. Nov 29, 2022 at 8:05 AM
    #42
    mendosaw12
    mendosaw12 New Member
    Hey DrZ I am having this issue as well. High beams work. When switc is turned on to only low beams, the high beam indicator shows but low beams don,t work... I have replaced new bulbs and checked fuses and relay within the engine compartment... I have tried to decipher the wiring diagram and opened the pdf on the inspection sheet poster earlier in this thread. Having a hard time figuring out the wiring sheet (do,nt have much experience with wiring diagrams).
  3. Jul 15, 2023 at 11:09 AM
    #43
    TacomaRockClimber
    TacomaRockClimber New Member
    My 2004 Tacoma had the same problem. High beams worked and the low beams did not. The bulbs "looked" good by eye and I didn't want to spend the $$$ money for new bulbs if that wasn't the problem. After closer inspection using a magnifier the bulbs were bad. By checking the bulbs closely first I probably saved Hours of unnecessary troubleshooting time. Even with magnification one bulb broken filament was early noticeable. Hope this helps
  4. Oct 24, 2024 at 12:45 PM
    #44
    changeyouroil
    changeyouroil New Member
    Just came to add another validation to the pile. Changing both headlight bulbs fixed this for me. It was strange because I first had a single headlight out and only for a couple of days before the second also went dead and because of high beams still working I thought I had a different problem. I found this post searching the web and wanted to share my appreciation by registering and confirming this also worked for me. Thank you tacomaworld!
