High Beams
Discussion in 'Lighting' started by JeepandYota, Apr 6, 2023.
  1. Apr 6, 2023 at 8:16 PM
    JeepandYota
    JeepandYota [OP] Member
    Hunter
    2012 Silver SR5 Tacoma
    Steel Bumper and Light bar
    So my high beams have started messing up. I was driving down the road and pushed the stalk forward to turn on the high beams and it turned off all of my lights including the gauges. What do I need to look at first? I’m new to the tacomas.
  2. Apr 6, 2023 at 8:18 PM
    Bishop84
    Bishop84 Well-Known Member
    Remove the bulbs and inspect for anything obvious with bulbs or connectors.
    HondaGM likes this.
  3. Apr 7, 2023 at 1:08 PM
    caribe makaira
    Caribbean, Puerto Rico
    I'd guesstimate that the stalk gave its last flick...
    Too Stroked and HondaGM like this.
  4. Apr 8, 2023 at 9:52 AM
    Toy_Runner
    Toy_Runner Well-Known Member
    99 4Runner SR5
    3" OME lift, heavy coils f/r 3/16" steel skids Modified Coastal Offroad diy bumper 5spd swap ('98 donor)
    Sounds like the stalk shorted out, or shorted something else out. Did the lights come back on when pulled back into the low beam position?
    HondaGM likes this.
  5. Apr 8, 2023 at 9:53 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
  6. Apr 10, 2023 at 4:52 PM
    JeepandYota
    Hunter
    Yes, my headlights return back to low beam wherever I pull the stalk back to normal. It’s just if I push the stalk forward to turn the high beams on it kills the headlights and my running lights stay on.
  7. Apr 11, 2023 at 5:01 PM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    Let's go for the easy stuff first. Do you have OEM / Toyota factory headlights or aftermarket? Have you checked the bulbs? It's not at all unusual to have both high (or low) beams go out at the same time.
  8. Apr 11, 2023 at 5:11 PM
    caribe makaira
    IF OEM, then one bulb (H4) dual filament (LOW /HIGH) per side.
  9. Apr 18, 2023 at 9:41 PM
    JeepandYota
    Hunter
    So I figured it out and it was a lot easier than I thought it would be. I just needed to change out the headlights even though the bulbs looked to be in perfect condition. After swapping the bulbs out I got my high beams back.
    CraigF and Stevie17 like this.
  10. Apr 20, 2023 at 4:40 PM
    Toy_Runner
    99 4Runner SR5
    I'm glad it was a simple issue [queue: "it ain't got no gazz in itt"]. The gaige lights turning off made it sound like a larger issue.
