High Clearance Rear Bumper
Discussion in 'Armor Tech Offroad' started by ArmorTech, Aug 19, 2013.
  1. Jun 26, 2014 at 9:34 AM
    #161
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    LOL
    B reak
    O ut
    A nother
    T housand
    x 10 with a jetski :D
  2. Jul 29, 2014 at 4:26 PM
    #162
    Pdugan6
    Pdugan6 Well-Known Member
    Patrick
    Sunnyvale California
    3 link solid axle 2011 Tacoma 4x4
  3. Aug 15, 2014 at 4:32 PM
    #163
    TheGreatPear
    TheGreatPear Well-Known Member
    Alex
    Gunsan, South Korea
    2013 DCSB TRD OR 4x4 V6 6 Speed
    Does the bumper have somewhere to mount the trailer light/brake plug? Ive seen it hanging down in a few photos and i was just wondering where people mount it, or if theres a spot for it underneath?
    And BTW as a potential buyer - I'm not phased by gripes on here. :playball:
  4. Aug 15, 2014 at 7:59 PM
    #164
    Pdugan6
    Patrick
    What I like to do is zip tie it through the license plate holes on the bottom of my license plate. This makes it very easy to take on and off for off-road use. Or you can drill and tap 2 holes
  5. Aug 15, 2014 at 8:00 PM
    #165
    Pdugan6
    Patrick
  6. Aug 27, 2014 at 2:09 PM
    #166
    garlicnation
    garlicnation Member
    Oakland, CA
    '14 Baja
    Will this fit 2014 tacomas?
  7. Aug 27, 2014 at 6:48 PM
    #167
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    Yep. Its the exact same rear end
  8. Sep 1, 2014 at 12:59 PM
    #168
    TheGreatPear
    Alex
    Gunsan, South Korea
    Ordered mine this weekend! Now for the 4 week countdown! :playball:
  9. Oct 10, 2015 at 10:11 AM
    #169
    Wolftaco
    Wolftaco Well-Known Member
    Luke
    Philadelphia, PA
    06 Overland Build
    Old Man Emu, Leer 100cc, Blacked Out Billet Grill, ARB Bumber, Warn M8000-s winch with under hood solenoid relocation, Stubbs HD Standard Sliders, diff breather
    What is involved in removing the swing gate tire carrier? Is it easy? PIA?
  10. Oct 10, 2015 at 6:19 PM
    #170
    lemons
    lemons LOCO 4X4
    Virginia
    07 TRD DC Offroad 4X4
    Icon coil overs W/King 14 inch 700lb springs and super bump bump stops, Allpro Expo leaf springs, Allpro Ubolt kit W/timbren Bump stops, Dif Drop Kit, Magnaflow Cat-Back Exhaust, Badges painted Rust-Oleum bed liner, Color Matched TRD Sport Grill W/Grille Craft Insert, TRD seat covers, Weather Tech Floor Mats, Flyzeye's , fog light anytime mod, ABS Off mod, ATO skid plates, ATO rear H/C bumper, BAMF sliders w/kick out, CBI front bumper, Engo 10000lb winch, Rigid D2 foglights, Piaa 510 fog lights, cobra CB w/firestix antenna, AFE snorkel
    Holy thread revival. It's one bolt to take off the swing.
    Slimwood Shady likes this.
  11. Oct 11, 2015 at 3:52 PM
    #171
    Wolftaco
    Luke
    Philadelphia, PA
    06 Overland Build
    Ok cool, if you don't mind me asking how long does it take to remove? Do you have to deal with spindle bearing and re-grease it everytime you put it back on? Comparing this bumper to Pelfreybuilt, just trying to decide between the two. Seems like the Pelfreybuilt is a PIA to remove and re-install gate from what others have said..
  12. Oct 12, 2015 at 11:25 AM
    #172
    lemons
    lemons LOCO 4X4
    Virginia
    It's easy, but messy. You should add new grease when you reinstall. I've only taken mine off once. No need to remove.
  13. Oct 13, 2015 at 10:23 AM
    #173
    Monkeyboy
    Monkeyboy Well-Known Member
    Grand Junction, CO
    2012 AC TRD Sport
    What he says. I've had mine for a couple years and only took it off once. One bolt. I probably should have regreased it when I put it back on, but I didn't. Seems OK.
    You can do it by yourself, but having a helper makes it much, much easier.
  14. Oct 14, 2015 at 7:36 AM
    #174
    ArmorTech
    ArmorTech [OP] Well-Known Member
    Adam
    Easy, one 3/4 inch bolt. As Monkeyboy said it is easiest with a helping hand, but it can be done by one person. Ben puts them on and off by himself a lot while building them.
    It should not be messy at all. We remove mine more times than we care to count due to how much my truck gets used for prototype work and pictures. The seals and suction from the grease should hold the inner sleeves in place. You should apply a bit of grease or never seize to the bolt, but that should be the only bit that is messy at all. Unless your seals are worn out somehow (maybe by the old non stainless steel sleeves rusting and rubbing at the seal surface) and drop the inner sleeves.
    Note this is an old pic that shows the old spring pin nut.
  15. Oct 14, 2015 at 8:05 PM
    #175
    Wolftaco
    Luke
    Philadelphia, PA
    06 Overland Build
    Thanks for all the info, I just ordered one from y'all! Can't wait till it arrives! After talking to Adam, I do actually think this is one of the best designed hinges of all the HC rear bumpers I looked into. I also think it looks the best with the gate removed, no pin sticking up. This is important cause I only plan to use the gate for long expo/overland trips where I need to carry more then 4 gallons of fuel and/or a second spare tire....
  16. Apr 15, 2016 at 9:09 AM
    #176
    clfaye
    clfaye New Member
    Hi - I just ordered one! Can't wait! I added a question to my order about whether it is possible to add a hole for a 7 pin trailer socket. Please let me know.
  17. Apr 15, 2016 at 1:49 PM
    #177
    ArmorTech
    Adam
    Thank you for your order! I replied to your email, but to answer the question for everyone else too. The HC rear bumpers don't have room in the bumper for the 7 pin connector, but the bumper does include a nice hefty bracket that holds the connector "behind" the bumper (towards the front of the truck) in a vertical position, facing down. This keeps it up out of the way, but still accessible when needed.
  18. Apr 21, 2017 at 9:19 PM
    #178
    jonny8990
    jonny8990 Well-Known Member
    Jon
    TN/KU
    12 Dcsb
    Icons up front kings in the rear, Dakar leafs,archive shackle flip, TG front and ATO HC rear bumper, ARB diff breather and lockers, 35s.
    Just picked one of these from the shop today! I have to say the build of this bumper is awesome! I'm a aviation sheet metal and composites guy and thought I could find a weld or unsupported angle on this thing. I couldn't find a thing to turn my nose to definitely a superior bumper design for Tacos. If anyone wants close up pics of the build or setup let me know you have till Monday morning before instal.
    singletrack_ftw likes this.
  19. Oct 3, 2017 at 10:14 AM
    #179
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I'm adding this bumper to my list of potential candidates, and I'm curious if the bumper locks in the open position? It looks like it does, but just wanted to confirm.
  20. Oct 3, 2017 at 6:16 PM
    #180
    jonny8990
    Jon
    TN/KU
    12 Dcsb
    I didn't get the swing out option so I'm not sure?
    EatSleepTacos likes this.
