High fuel trim on bank 1 causing P0420 code?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kyle4awhile, Jan 2, 2015.
  1. Jan 6, 2015 at 7:59 AM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    No, but if you really wanted you could just plug in one side.
  2. Jan 6, 2015 at 8:47 AM
    offgrid taco
    offgrid taco Well-Known Member
    ned
    mass
    24 trd off road bronze oxide
    Could be a wideband o2 sensor.
  3. Jan 11, 2015 at 5:19 PM
    kyle4awhile
    kyle4awhile [OP] Giv' Er
    Kyle
    Northern Utah
    4.0L V6 Double Cab Long Bed
    Magna Flow Muffler, Spyder HID headlights, 3" Pro Comp Lift, Rockstar 2 wheels, Big Tires!
    So I found out the boxes were just a Bosch "smart link" to get your plug on their sensor.. I've heard not using Denso could throw the code, so I switched the sensors, thinking it would just be the one that the computer doesn't like, but I got the same code after the 2 drive cycles. So I think it's gonna be the simulators at least for now, as I've already spent enough in cats for my taste. My guess now is that the cat I got was bad. Fortunately the guy I got it from is willing to refund me based on my evidence that it isn't anything else. Here in the Salt Lake Valley we have some of the worst air in the country due to inversion in the winter, I cant justify hollowing out the cats with this air, but at the same time I don't feel bad if my cats are only performing slightly under efficiency, when the alternative is new $750 cats. Thanks all for your help, I'll update after the simulators are in.
