high heat ac only
Discussion in '1st Gen. Tacomas (1995-2004)' started by johnnyb65, Jan 24, 2014.
  1. Jan 24, 2014 at 2:59 PM
    johnnyb65
    johnnyb65 [OP] Member
    john
    columbia, md
    97 tacoma 4wd
    My 97 has high blower speed only. Any suggestions on where to start diagnostics to fix problem
  2. Jan 24, 2014 at 3:16 PM
    Taylor
    Taylor Check out NASA Spec3!
    Taylor
    Vienna, Virginia
    NASA Spec3 RaceCar
    Check the switch itself?
  3. Jan 24, 2014 at 4:54 PM
    MyWifesTacoma
    MyWifesTacoma Active Member
    southern Colorado
    On our ex truck (a '97) the blower switch was connected to a resistor pack, which was below/behind the glove box. The resistor pack is (probably) either disconnected (mine) or failed.
    The normal symptom is high-speed only, as high bypasses the resistor pack.
    The pack is cheap and looks like this:
    http://www.autopartsnetwork.com/toy...=google_base&gclid=CIX6zqGOmLwCFY07Mgodnz8A_A
    Google "toyota blower resistor" and you'll find lots of info.
  4. Jan 25, 2014 at 12:54 AM
    Pakrat
    Pakrat Well-Known Member
    Brian
    Washington,State Columbia gorge
    02 tacoma xtracab 4x4 stock
    Front dome light added,light reminder added,door chime mod, added 2nd gen 4runner headrests,grey wire mod, 2lo mod, more later.
    Your resistor is bad. It controls the blower motor speeds.
  5. Jan 28, 2014 at 9:12 PM
    johnnyb65
    john
    columbia, md
    97 tacoma 4wd
    Thank You! For your responses. I'll give that resistor a try. lost a couple of days to the flu, now it real cold again, go figure!
  6. Dec 29, 2015 at 8:30 PM
    Fujimori17
    Fujimori17 Well-Known Member
    1996 3.4L Standard Transmission 4x4 Extra cab
    Did you ever figure it out? I have a 96 and I'm having the same problem where when I hit a bump or something the blower will kick on or off. This is the only thread I found with our years as the other later first gens have different hardware (or so I think)
  7. Dec 30, 2015 at 3:41 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    this is the solution
  8. Dec 30, 2015 at 6:06 PM
    Fujimori17
    OK so is that going to be behind the climate control panel or behind the glovebox by the motor itself?
  9. Dec 30, 2015 at 8:24 PM
    keakar
    karl
    louisiana
    behind the glove box, the fan motor is located more underneath and on the bottom of the box but the resistor relay (I am told) is mounted right there behind the glove box so you should see it as soon as you move the glove box out of the way
  10. Dec 30, 2015 at 8:29 PM
    Fujimori17
    Alright cool thanks I'll give it a go this weekend probably
  11. Dec 31, 2015 at 9:20 AM
    Fujimori17
  12. Dec 31, 2015 at 9:30 AM
    keakar
    karl
    louisiana
    yep :thumbsup: but to be honest I prefer paying a little more and using the oem replacement parts whenever I can if they arent crazy expensive and in this case the genuine oem one is cheaper http://www.toyotaonlineparts.com/oe-toyota/8713835040
    it is part number 14 shown in the blow up image
  13. Dec 31, 2015 at 12:48 PM
    Fujimori17
    OK awesome thanks again. I think I might also have a bad blower switch because if I wiggle it the fan will kick back on sometimes. Unless that's also a symptom of a bad resistor
  14. Dec 31, 2015 at 1:08 PM
    keakar
    karl
    louisiana
    that's possible (intermittent internal resistor connections) so replace the resistor first then retest the switch
  15. Jan 31, 2016 at 9:26 AM
    Fujimori17
    So I finally got around to it and sure enough it was the blower control switch. The problem I'm faced with now is that I'm afraid the harness is bad and will subsequently fry my new blower switch. I'll attach pics so you guys can see what I mean. I plugged the new one in and it works fine but I'm worried that over an extended period of time it will go as well. uploadfromtaptalk1454261137905.jpguploadfromtaptalk1454261162617.jpguploadfromtaptalk1454261172034.jpg
  16. Jan 31, 2016 at 10:46 AM
    keakar
    karl
    louisiana
    that looks bad , like a fire just waiting to happen
    I suggest you go to salvage yard or find someone with a parts truck selling parts and buy that plug with as much attached wire that comes with it from them and replace that plug and the fried sections of wire.
    I would leave that unplugged until you do or if you really need it, then cut that sleeve off and tape up those wires individually so they cant short out. but those wires are still fried and will eventually break apart from being overheated so much so im not saying its ok to leave it like that.
  17. Jan 31, 2016 at 10:48 AM
    Fujimori17
    That's what I was thinking. Would I be able to find that plug online? I'd rather just buy a new one so I know what I'm getting. I can't seem to find the part online though.
  18. Jan 31, 2016 at 10:51 AM
    keakar
    karl
    louisiana
    nope, only way to get it is to buy the complete dash wiring harness at around $1500
    as I said, find someone with a parts truck willing to cut it off the harness plus all the wire they can leave on it, hopefully 8-10" worth
  19. Jan 31, 2016 at 10:52 AM
    Fujimori17
    Wow. Well that sucks. Thanks for the help
  20. Jan 31, 2016 at 10:54 AM
    keakar
    karl
    louisiana
    just remember to solder the connections and use heat shrink to cover the solder joints so its better then new after.
    its a PITA but you'll find one soon im sure
