High idle 3.4
Discussion in '1st Gen. Tacomas (1995-2004)' started by Otis1297, Nov 2, 2019.
  1. Nov 2, 2019 at 4:11 PM
    Otis1297
    Otis1297 [OP] Member
    1999 Tacoma
    I just replaces IAC and cleaned the throttle body. Rpm in park 1200 and drive 950. Replaced some vacuum lines. I also unhooked battery for awhile.
    Any suggestions would be appreciated and videos.
    Thank you
  2. Nov 2, 2019 at 7:05 PM
    Clucky
    Clucky Well-Known Member
    W
    WC to EC back to WC
    00 SR5 Stock 5 Speed
    & 12 TRD Stock 6 Speed
    What was it before the new IAC valve? Clean the MAF sensor?
  3. Nov 3, 2019 at 7:44 AM
    Otis1297
    1999 Tacoma
    It was running higher at 1500
  4. Nov 3, 2019 at 11:43 AM
    Otis1297
    1999 Tacoma
    I cleaned MAF as well
  5. Nov 3, 2019 at 1:28 PM
    Timmah!
    Timmah! Well-Known Member
    TIM
    Is the IAC an OEM replacement?
  6. Nov 3, 2019 at 5:38 PM
    Otis1297
    1999 Tacoma
    No it was not an OEM.
  7. Nov 3, 2019 at 5:50 PM
    Timmah!
    TIM
    Maybe you can pull a used OEM one off an engine at a PicknPull and see if it fixes the problem.
    Otis1297[QUOTED][OP] likes this.
  8. Nov 4, 2019 at 2:29 PM
    MalinoisDad
    MalinoisDad Misanthropic dog person
    Michael
    01 TRD PreRunner 5VZ
    5100s w/ 881s, JBA UCAs, J59s, other stuff and things
    Something similar happened to me a few years ago after I cleaned my throttle body. I also cleaned my MAF in the same tinkering session. I observed high idle for about a day (same numbers as OP) and then it went back to normal. I assumed the ECU needed to relearn the A/F ratio after I removed the excess carbon from around the butterfly valve.
  9. Nov 4, 2019 at 2:32 PM
    eon_blue
    Azusa, CA
    Normal for the idle to be a tad high after cleaning the MAF and/or throttle body. Mine idled around 1250 and slowly went back to normal over the course of a day.
    If it idles really high or doesn't go back down then you might have issues with the throttle body needing to be re-bored. Sometimes when they get old the butterfly valve wears a small groove in the throttle body, when you clean it that groove now lets air past the valve at idle and messes with the idle speed.
    Give it a couple days and see if it goes down on its own, usually does
    ThunderOne likes this.
  10. Nov 5, 2019 at 9:27 AM
    Otis1297
    1999 Tacoma
    Thank you guys, I will try this. I really appreciate the help
