High Idle After Reving Engine
Discussion in '1st Gen. Tacomas (1995-2004)' started by AdamB188, Aug 12, 2019.
  1. Aug 12, 2019 at 3:24 PM
    AdamB188
    AdamB188 [OP] Member
    Adam
    2003 Tacoma 4x4 2.7
    I have a 2003 Tacoma 2.7l 4x4 and I have noticed it idling at about 2000 rpm sometimes. When I am offroading the truck runs and idles fine until I go and rev it up to get through some mud. I always fether the gas in the mud and don't just hold it right on the red line but it aways idles high after I do this. Sometimes it will drop back down to 1000 rpm and jump back and forth between 1000 and 2000.
    Any help would be much appreciated!
  2. Aug 13, 2019 at 1:15 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    See if the throttle body is hanging up
    crack in air intake opens as the truck flexes .
    Some How your getting extra Air into the engine
    Broken Engine Mount allowing things to move.
  3. Aug 13, 2019 at 3:01 PM
    AdamB188
    Adam
    2003 Tacoma 4x4 2.7
    I could not find any cracks and the motor mounts are all good. I did, however, find a code for EGR insufficient flow. I cleaned the EGR valve about 2 months ago as well as the EGR tube but the code still remains. Do you think this could be related?
  4. Aug 14, 2019 at 12:01 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Quite Possible
