High idle after spark plugs, maf/TB cleaning, fuel filter
Discussion in '1st Gen. Tacomas (1995-2004)' started by austinramsay, Oct 9, 2013.
  1. Oct 9, 2013 at 9:06 AM
    austinramsay
    austinramsay [OP] Well-Known Member
    Austin
    Yuma, Arizona
    2001 Tacoma TRD Doublecab
    Before changing spark plugs, fuel filter, seafoam, and cleaning the maf/tb it idled around 800 in park and 500 in drive. Now after all that it idles around 1300-1400 in park and 750-800 in drive. I was thinking a vacuum leak or something but i cant find any. Ive unplugged the battery so itd reset the ecu but that didnt help either. Any ideas?
  2. Oct 9, 2013 at 9:25 AM
    jspansel
    jspansel Just duct tape it
    Jay
    Central OR
    01 V6 Xtra Cab Tacoma, 5 Speed, 4x4, Lifted
    5100s front at 2.5" with Moog replacement springs, 5100s in rear with 2" Wheeler's AAL
    Did you clean the IAC? Maybe some gunk from cleaning the TB got in it?
  3. Oct 9, 2013 at 9:30 AM
    zbaldo
    zbaldo Well-Known Member
    Ozzy
    Torrance, Ca
    99 4Runner SR5 4X4
    Stock as Stock can be with duratracs and a roof rack
    I've had that before double check all your vacuum lines and if they all look good then drive the car for a couple weeks and it should go back to normal, I removed the efi fuse for a bit too while cleaning
  4. Oct 9, 2013 at 10:04 AM
    austinramsay
    Austin
    Yuma, Arizona
    No i didnt but if in a couple weeks it doesnt go back to normal i will.
    Alright sounds good, yeah ill double check today.
  5. Oct 11, 2013 at 9:44 PM
    zbaldo
    Ozzy
    Torrance, Ca
    99 4Runner SR5 4X4
    no problem just write back on how things went after if it settles down or not
  6. Oct 11, 2013 at 9:53 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Normal.
    You cleaned the TB.
    There was gunk built up around the edge of the butterfly and the bore.
    You removed that.
    There is now more space between the butterfly and the bore.
    The ECU will adjust after a few days and it relearns the idle trims.
