High idle after throttle body cleaning
Discussion in '1st Gen. Tacomas (1995-2004)' started by NegroTundra, Jan 9, 2011.
  1. Jan 9, 2011 at 12:17 PM
    NegroTundra
    NegroTundra [OP] Well-Known Member
    Land of Enchantment
    03 Tacoma TRD 4WD 5 spd
    3.4 V6 85,400 miles
    Cleaned my throttle body today along with spark plug change. Before I performed this maintenance truck seemed to running fine, with warmed up idle around 750-800rpms. Performed said maintenance and cold, will idle 2000 rpm's, settling down to 1100 rpm when warm.
    I did do a thorough job of cleaning the TB; I took it off completely and cleaned both sides of butterfly flap. Thoughts?
  2. Jan 9, 2011 at 12:21 PM
    ToucanV13
    ToucanV13 You think I was rollin out here naked?
    San Diego and Colorado
    Infideled out TRD Sport 4X4
    285/70 Hankook AT-M, Window vents, TRD CAI, TRD Cat-back exhaust with WickedFlow can, AFE Throttle Body Spacer, Billy 5100 @ 2.5 and 1" block rear, RBP nerf bars, Halo HIDs, 20% tint up front
    I had the same problem, make sure the butterfly valve is closing all the way, truck was fine after I took it off and flapped it a couple times and wiped it again
    Dalandser likes this.
  3. Jan 9, 2011 at 12:31 PM
    NegroTundra
    Land of Enchantment
    Thanks I'll try that
  4. Jan 9, 2011 at 12:41 PM
    SunDevilTacoma
    SunDevilTacoma Well-Known Member
    Doug
    Gilbert, AZ
    04 Wht Double Cab PreRunner
    Turn signal relocation, built in fog light conversion, 4" deck plate
    Mine idled high right after I did it, but it settled down after a couple days.
  5. Jan 9, 2011 at 1:01 PM
    chacotaco
    chacotaco Well-Known Member
    Travis
    Albuquerque & Palo Alto
    2011 SSM TRD SPORT DCLB
    Black Snugtop XtraVision Sleep Deck.
    Unplug batery, make a sandvitch, take a shit,shower and shave , and the hook battery back up. It supposedly allows a "ECU Reset" that forces a recalibration of the MAF and deletes old data that causes algorithm update hysteresis.
    Xbeaus and Dalandser like this.
  6. Jan 9, 2011 at 4:35 PM
    RCBS
    RCBS "Cause I'm mighty proud of that ragged old flag."
    Appalachia
    06 Main Runner OR
    This^ X2.
  7. Jan 11, 2011 at 1:59 AM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    Brazoria County Texas
    15 DCSB SR5 MGM
    :laugh: Reset the battery and give it a few days for the computer to re-learn the change. It will be fine. :cool:
  8. Jan 18, 2011 at 12:19 PM
    .Trdtaco315.
    .Trdtaco315. Well-Known Member
    Will
    Santa ana
    03 Trd SR5 Prerunner
    im gunna clean mine now =] easy stuff?
  9. Jan 18, 2011 at 12:48 PM
    NegroTundra
    Land of Enchantment
    yes. I would recommend taking the TB completely off so you can thoroughly clean both sides.
    Update, I unplugged battery for 30 minutes, and after one trip to walmart my idle was fine again. Thanks guys.
  10. Jan 18, 2011 at 1:14 PM
    .Trdtaco315.
    Will
    Santa ana
    nice, ill get on mine now.
  11. Jan 18, 2011 at 1:19 PM
    joerussell610
    joerussell610 When all else fails read the directions
    Him
    Making myself at home in your house
    2005 DC Sport Edition 4x4
    K&N, fog light mod, remote rear halogen fogs mounted under rear bumper, TRD skid plate, Flux Capacitor, Mr. Fusion upgrade soon
    Mine went away after a couple of days and now runs like a HOT BITCH! Response is unreal! :burnrubber:
  12. Jan 18, 2011 at 2:10 PM
    .Trdtaco315.
    Will
    Santa ana
    im so pumped to do mine! is it just the 4 bolts holding it on? and all the little attachments? cuz im about to do it right now.
  13. Jan 18, 2011 at 5:19 PM
    NegroTundra
    Land of Enchantment
  14. Oct 25, 2012 at 8:04 AM
    toy4x4ota
    toy4x4ota New Member
    dallas
    reno
    stock 97 2.7l
    I know that this is an old thread, but I like to use the search.
    I just cleaned out the throttle body on my 2000 2.7l and now I am getting high idle RPMs. Will unhooking the battery like mentioned work for this truck as well, or this specific to the 3.4l.
    When I cleaned out the TB, I did remove it as well as the IAC to prevent junk from getting in there.
    Dallas
  15. May 29, 2015 at 2:49 PM
    Chevyss
    Chevyss New Member
    97 4Runner
    I'm from Fort Worth TX, I cleaned my TB on my 97 4Runner today. Everything turned out great.
  16. May 18, 2017 at 4:39 PM
    tonsaephan
    tonsaephan New Member
    Ton
    04 Tacoma
    Hello, bringing up an old thread but need help. 04 Tacoma 2.7L, cleaned throttle body and changed gasket now has a high idle. I unplugged battery like stated above and it's also been a few days already and still has not gotten better. Any help please.
  17. May 19, 2017 at 1:07 AM
    Dalandser
    Dalandser ¡Me Gustan Las Taco-mas!
    Anthony
    Downey, LB
    Empty Wallet Mod
    Did you make sure the butterfly valve is closing all the way at idle?
  18. May 19, 2017 at 1:16 AM
    tonsaephan
    Ton
    04 Tacoma
    how can I check if it's closed all the way? when u rev it up the RPM will stay at 1500~
    seems like the throttle body doesn't return to the lowest point it can, therefore if I manually twist it the RPM will settle back to normal. buy i don't want to be doing that everytime, if you understand?
  19. May 19, 2017 at 1:19 AM
    Dalandser
    Anthony
    Downey, LB
    Empty Wallet Mod
    Hmmm, the post up top said to tap it a few times or open and close it manually to see if it's just a little stiff towards the closed position and it starts to shut all the way.
    @mechanicjon
