High Idle and Check Engine Light?
Discussion in 'Technical Chat' started by tacomarustingaway, Mar 12, 2011.
  1. Mar 12, 2011 at 6:56 AM
    tacomarustingaway
    tacomarustingaway [OP] Well-Known Member
    Hi,
    My '01 tacoma 4x4 with 2.7L engine/manual transmission goes into very high idle sometimes. I have to slap my gas peddle to get it to stop and then the check engine light comes on for about 50 miles or so. It's been doing this on and off for about 6 months. Any suggestions on what is causing this? I've had both O2 sensors replaced and it still does this.
    Thanks
  2. Mar 12, 2011 at 7:09 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    sounds like it could possibly be a bad crank position sensor or throttle position sensor.
  3. Mar 12, 2011 at 7:32 PM
    tacomarustingaway
    Is there any way a mechanic can test for this? It doesn't do it all the time.
    Thanks for the help
  4. Mar 12, 2011 at 7:43 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    Next time the cel goes on.......go on to autozone and get them to pull the code. It'll be easier to diagnose that way.
  5. Mar 13, 2011 at 9:11 AM
    tacomarustingaway
    Thanks. I'll do that.
