High idle and idle bouncing
Discussion in '1st Gen. Tacomas (1995-2004)' started by Cmuelrath, Feb 9, 2023.
  1. Feb 9, 2023 at 9:14 PM
    Cmuelrath
    Cmuelrath [OP] Active Member
    Colton
    2001 Tacoma 2.7
    I recently bought a 2001 4x4 2.7 5 speed. Pulled the motor and put a new head on it, timing chain kit and All new seals. I got everything back together and put back in. When the truck is cold it idles smooth but high (2 thousand rpm’s). Once truck is warm it bounces from 1 to 2 thousand rpm’s back and forth consistently. When driving it drives and runs fine. I thought it was a idle air control valve so ordered one off of rock auto and didn’t change anything. Sprayed the whole motor with carb and choke clean to check for vacuum or gasket leaks and didn’t seem to have any. Any idea what the problem could be? I’m lost at this point. Any help appreciated.
  2. Feb 9, 2023 at 9:17 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Any check engine light codes?
    mine was idling high when i had egr issues after putting the head back on, but don’t recall bouncing
  3. Feb 9, 2023 at 9:19 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    It's possible that the idle will settle down with time while the ECM relearns.
    GilbertOz likes this.
  4. Feb 9, 2023 at 9:22 PM
    Cmuelrath
    Colton
    2001 Tacoma 2.7
    I disconnected the battery for a minute tonight after installing idle air valve and reconnected. I’ll see if it changes anything in the morning. I’m not so much concerned with the high idle but the bouncing between the 1 and 2k. It’s as if I have a vacuum leak but almost certain I don’t.
  5. Feb 9, 2023 at 9:22 PM
    Cmuelrath
    Colton
    2001 Tacoma 2.7
    No check engine lights.
  6. Feb 9, 2023 at 9:30 PM
    dj4230
    dj4230 Member
    Dean
    2002 Xtra Cab 2.7L 4x4
    mine was acting similarly with a bad ECT sensor (back of the block), high idle when cold and bouncing. but typically stopped bouncing once it was warm
  7. Feb 9, 2023 at 9:32 PM
    Cmuelrath
    Colton
    2001 Tacoma 2.7
    Mine doesn’t bounce until it’s warm. Only high idle cold then warm starts bouncing
  8. Feb 10, 2023 at 6:19 AM
    Cmuelrath
    Colton
    2001 Tacoma 2.7
    Drove it to work this morning and pretty much same thing. Noticed it seemed to not have such a wide range when bouncing rpm’s now. Only from about 1500 to 2 thousand rpm’s
    Bivouac likes this.
  9. Feb 11, 2023 at 12:48 AM
    JustADriver
    JustADriver Well-Known Member
    1996 Tacoma 3.4L V6 2WD 5-lug AT 5VZ-FE
    A dirty MAF sensor can cause issues with high idle or moving up or down nonsensically.
  10. Feb 11, 2023 at 5:34 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    This only happens when stopped .
    AC compressor cycling on and off
    Check the throttle body linkage for hanging up.
    I had the firewall crack that made that happen. I only noticed while the truck was stopped never driving.
    Cmuelrath[QUOTED][OP] likes this.
  11. Feb 11, 2023 at 9:28 PM
    Cmuelrath
    Colton
    2001 Tacoma 2.7
    Finally threw a check engine light and says it’s the egr transducer. Going to put one in and see if that fixes it
    Steves104x4 likes this.
  12. Feb 11, 2023 at 9:33 PM
    3xYota
    3xYota Member
    1999 TRD
    Stock
    Try a hot soak with some sea foam. It does wonders. You have nothing to loose except $7 for the can if you get it at walmart vs $14 at autozone.
    Cmuelrath[OP] likes this.
  13. Feb 11, 2023 at 9:35 PM
    Cmuelrath
    Colton
    2001 Tacoma 2.7
    Take it apart and soak or just remove it and soak? I’ll try this. Doesn’t seem to difficult to remove so going to swap my brothers on off of his truck to verify it’s this part. Thank you!
  14. Feb 12, 2023 at 8:01 AM
    3xYota
    3xYota Member
    1999 TRD
    Stock
    Just pull a vacuum line and slowly add the fluid. Let it sit for 15 min then run the truck till it burns everything off. Youtube has a ton of these videos.
  15. Feb 12, 2023 at 10:18 PM
    Cmuelrath
    Colton
    2001 Tacoma 2.7
    Is there a better vacuum line to pull to run it though if I’m mainly focusing on egr?
  16. Feb 14, 2023 at 7:09 PM
    3xYota
    3xYota Member
    1999 TRD
    Stock
    I think it depends on ur motor. On my 3.4 I just pull the line off the brake booster.
  17. Feb 21, 2023 at 6:46 AM
    Cmuelrath
    Colton
    2001 Tacoma 2.7
    Put a new egr valve on and it fixed the idle bouncing problem stays at a steady high idle now. Now the idle is higher and stay right around 2600 rpm’s consistently. Egr vacuum motor or vacuum solenoid? Or temp sensor on back of motor? Thoughts
  18. Feb 21, 2023 at 7:06 AM
    Jakuku Pahwheenis
    Jakuku Pahwheenis i provide useless forum contributions
    J Phoenix
    South Carolina
    2003 Xtracab 2.7L 3RZ-FE 4x4 manual 245K+ miles
    I'm in a similiar boat. Idles 1500-2000. slowly climbs to 2000 and then drops to 1500 or so after a few minutes and climbs again. Drives fine, but when coasting in neutral, it bounces between 600 and 1500 or so I think, then settles back up to the high idle when stopped. Just wierd. Did you do anything else to yours? On mine, I had deep cleaned the intake, deleted EGR, deleted Cats, added street headers and CAI. Also replaced the various valves in the evap vacuum lines. So you might be like, well no wonder yours is acting wierd lol. Well I figured it was just trying to relearn itself and would settle down. Probably driven about 75 miles in it that way so far and its still doing its thing. Hopefully it won't have any negative long term effects. I haven't done a vacuum check on it, but meant to. Probably will this afternoon. Following to see if you figure anything out.
  19. Feb 21, 2023 at 7:36 AM
    Xbeaus
    Xbeaus Well-Known Member
    Beau
    Black hills South dakota
    98 Tacoma 3.4 5 speed SR5 limited TRD 4x4
    Toytec coilovers. Height adjustable Bilstein's. 265/75/16 MT. TRD wheels. Rebuilt r150f. Marlin clutch kit. All kinds of new parts...
    Bouncing idle almost has symptoms of throttle position sensor. Any way to try a different tps to rule that out?
  20. Feb 21, 2023 at 7:55 AM
    Cmuelrath
    Colton
    2001 Tacoma 2.7
    it’s not bouncing anymore fixed that problem now just really high idle
    Xbeaus[QUOTED] likes this.
